Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony wega kv-36fs100 no signal message - Sony FD Trinitron WEGA KV-27HS420 27" TV
Posted by pfojr1953 on
    Top Expert:
  • Sony Master
  • 76,416 Answers
Check and replace its tuner. It is faulty. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Posted on Oct 06, 2012
2 Related Answers
Anonymous
SOURCE: sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Posted on May 01, 2009
Anonymous
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Kv-36fs100 power supply voltages
Just come over to me by Fixya comment with your email address. I'll send a copy of the repair book to this set to you by return mail. It has all details. OK?
Sep 02, 2012 | Sony KV-36FS100 36" TV
HOW DO I GET RID OF THE SQUARE MESSAGE BOX?
Press the "CC" button on the remote control once.
Aug 27, 2012 | Sony KV-36FS100 36" TV
MY WEGA SONY KV-27FS13 TV - HAS SOUND THROUGH CABLE BOX BUT NO PICTURE. I DONT KNOW WHAT CHANNEL TO SET IT ON- AND DO I PUT IN ON DIGITAL OR ANALOG?
Hello, hopefully you can help me. I just brought a used sony wega kv-27fs13 27 flat-screen tv. But when I put the cable wire in the TV it says No Signal. Do you know what the problem could be?
Jul 23, 2011 | Sony KV-27FS13 27" TV
Sony KV-36xb1400 convergance Problem
Its not matter of service code only. You also need service data to fix it. But question is, how data is being corrupted? It seems hardware failure in your TV set.
Jul 31, 2008 | Sony KV-36FS100 36" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
KV-36FS100
try this site
http://www.repairfaq.org/sam/tvfaq.htm
good luck!
Mar 14, 2008 | Sony KV-36FS100 36" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
