SOURCE: how to replace a switch-lid on a whirlpool washer
You can check various appliance repair websites for self help manuals, or you can follow these steps:
First of all, unplug your washer. You will need to remove the console
in order to get to the lid switch. I believe your washer has release
tabs under the console at each front corner. Simply slide a putty knife
straight in from the front at each corner and push in while lifting up.
You should feel the release tabs push in and the console will pop up.
Or, you may have a console that has removable end caps. They can be
removed by gently prying up on the top of them from the rear on each
side. You may have to use a small screwdriver for this. The caps should
pop right off. Once removed, you will need to loosen a screw under each
cap. Once you have the console loosened, carefully lift it up and lay it
back over the rear panel of the washer in its resting position. Be
careful not to damage the small plastic hinges that hold it in place.
Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2.
There will be two brass colored clips. You will need to remove these to
remove the machine casing. Place a flat blade screwdriver straight down
into the opening on top of the washer and into the groove of the clip.
Push the screwdriver away from you while holding into the groove and
the clip will release.
3. Open the lid of the washer and place
your hand under the front rim of the opening (DO NOT grab the wash
tub). Now pull the case from the frame by lifting from the back first.
You
do not have to remove it all the way from the frame. Just enough to
gain access to the switch. All there is to the switch is a couple of
screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1.
While looking down through the lid opening, place the front lip of the
machine case UNDER the washer frame and start leaning it back onto the
frame. There are four small cleats that must fit into four slots on the
case or the washer will vibrate. Make sure the frame is seated
properly, lean forward from the front of the washer, grasp both sides
of the rear panel and pull towards the case. The rear panel should be
seated and flush with the casing before inserting the retaining clips.
2.
Insert the brass-colored clips into the slot on the washer rear panel
first, then push straight down into the opening on the top of the
washer with some force. If you have the case seated correctly, the
clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Have you purchased a lid switch yet? Most major appliance repair centers carry them. The price is about $35. If you have not purchased one yet, let me know what your EXACT model number is (located on the rim of the wash tub opening under the lid) and I will locate a part number for you. I hope this information helps you.
SOURCE: replacing lid switch on whirlpool top load washer
Here ya go. Click on
the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you need further assistance, please post back and let me
know. I hope this helps you.
SOURCE: replace the lid switch on washer
There are 2 screws at each corner on the front of the control panel. Remove these. Then gently pull out and up on the control panel and lift it up to expose the 2 clips on each side of the cabinet. these should pop out easily with a flat head screw driver. There should be one wire assembly plastic clip that you also need to release. At this point, the entire cabinet will lift towards you by grabbing the back and pulling towards you. At this point, the lid switch can easily be changed with 2 screws. It's not as hard as it sounds.
SOURCE: replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
SOURCE: replace lid switch on whirlpool type 111 washer
The following link explains step-by-step how to repalce a lid switch on your washer:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
I hope this information helps you. If you have any questions, please let me know.
