Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Possibly the defrost heater could be faulty or the defrost thermostat or defrost thermistor (sometimes called D-Sensors I believe). If you turn off the fridge and let it defrost itself for 12 hours and then start it again, it may work fine for a week or two (or may even be totally fine in case you left the fridge or freezer door open by accident).
Posted on Sep 05, 2013
SOURCE: freezer doesn't cool, refrigerator is startin to warm up
There can be several reasons to it.
1.Dust collection can create such a thing but it does not happen directly you should understand the performance loss with in time.
2.Gas leakeage in the cooling circuit.(You need a technican to correct it)It happens due to corrosion.
3.Compressor failure.(This is really a small percentage)
4.If this is a no frost appliance not properly closed door.Make the evap blocked.You can unload the appliance.unplug wait for a day then start again.
Posted on Sep 27, 2009
SOURCE: ice maker not making ice
If your ice maker has stopped producing ice completely, check these, in this order:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Posted on Jan 12, 2009
SOURCE: model no 253.5711860 side by side the freezer will
The board will not fix the problem if the heater or the hi temp limit is bad. It sounds like the "computer" is not the problem. Have someone come out and diagnose the problem.
Posted on Oct 29, 2009
Apr 26, 2015 | Samsung RS263TDWP Side by Side...
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Aug 26, 2011 | KitchenAid Superba Architect KSCS25INSS...
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 27, 2009 | GE Refrigerators
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Jul 10, 2009 | Kenmore Refrigerators
May 29, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
131 people viewed this question
