Posted on Oct 05, 2012
Pioneer BCS-FS525 problem/not working properly
Hi! Was about to install my new system when it suddenly freezed and stopped working. I pulled out the cord, waited 15-20 seconds, and then pulled it back in again. Now, the only thing working is the on/off-button and the volume wheel; nothing else. The TV doesn't even recognize the system. What is wrong, and how do I fix it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
437
Points
0
I had similar problems. Try to first switch on your TV and then the Home Cinema set. If I switch it on without the tv I the systems freezes also
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 03, 2009
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Anonymous
  • 263 Answers
  • Posted on Jul 29, 2009
SOURCE: NO SOUND IN THE TV MODE.....
Try pressing the mute button on the remote
Scrolling quickly through albums on an ipod connected to a Pioneer BCS 717
i brought an mp3 player and i need to know how text on this stupid thing
Fridge and freezer suddenly not working only 1.5 yrs old
I guess the culprit in this case is the compressor.. Do you hear a sound when you are near the refrigirator.. it will be like a fan rotating at a high speed...
2answers
Tablet cursor works for a few seconds then freezes (G-Pen F350; Windows Vista). I've uninstalled and reinstalled the driver 3 times already. The tablet worked perfectly fine yesterday when I bought it, but...
Hi
Is that the same with computer. If yes, just run the system restore. choose the date you want to restore.
If not, uninstall software that you install before that might corrupted the program.
Hi. i have problem bcs the paper is not caming
s switch off and on the problem solve but paper jam
System hangs up frequently
Might be a loose RAM (memory stick). Try removing it and then connect it again properly and see if it solves the Problem.
Installed new update to fix freezing problem - created new one
I had the same problem. Mine originally stopped at 23/92 files. Then after a cool night, I started it again in the morning and got 91/92 files loaded before it started to fail again. I left the disk in and after about 20 fails in a row, it finally loaded!!! Recommend you just leave it in there and it should work. good luck
Pioneer DEH-50UB
Hi again,
Appreciate the direct "Ask Me".
Let's try a process of elimination based on:
  • the Pioneer DEH-50UB is working OK other than it displays error communicating with the iPod at certain times (intermittent);
  • the iPod when played alone/by itself does not exhibit any freezing/hanging problems;
  • the iPod to DEH-50UB connector/cable CD-IU50 is in good working order since if it is not, then the iPod would not even be heard on the Pioneer;
  • the Pioneer's wiring are OK otherwise it would not be working.
Which leaves us the possibilities of:
  • corroded/dirty USB port/interface on the Pioneer DEH-50UB;
  • loose USB port on the DEH-50UB;
  • loose or corroded terminals on the CD-IU50;
  • corroded/dirty contacts on the iPod;
  • RF interference from communications equipment such as CB radios, 2mtr Amateur, mobile phones;
  • electrical interference/noise from the vehicle such as horn relay, A/C relay, fan relay, alternator;
  • electronic noise from navigation/GPS mobile equipment;
  • keyless/remote alarm/security system.
Additional actions that could be explored/done:
  • installation of choke/filter capacitor along the red & yellow wiring of the DEH-50UB;
  • additional grounding/groundstrap of the DEH-50UB to the chassis/metal/body of the vehicle.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
2answers
Pioneer DVR-K17RS ATA ACER CODE=39
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
