Question about Sanyo DP50747 50 in. Plasma TV
Sanyo 50 inch DP50740 turns on for 2-3 seconds then turns off
Sanyo 50 inch DP50740 what happens is when I plugin the TV nothing happens but when I push the power button the power light turns on for 2-3 seconds then turns off (when I push it again it will do the same thing 3 or 4 times then it stops and I will need to unplug the TV, I tested the fuses and they are good, I have looked at the board nothing looks wrong the caps look good no dark spots on the board we don't know what is wrong whit it, I know that it just stop working one day. we also got a new power board but that did not fix it Nathan
Posted by nat400 on
  • nat400 Oct 06, 2012
    what do you think about buying a repair kit it will cost $120 for all the boards and if I buy it what boards should swich outhttp://www.shopjimmy.com/sanyo-dp50740-p...
marco
    New Friend:
  • 35 Answers
Try to change the Inverter board (Buffer board).
Posted on Oct 05, 2012
  • nat400 Oct 08, 2012
    what do you think about buying a repair kit it will cost $120 for all the boards and if I buy it what boards should swich out.
  • marco Oct 09, 2012
    Go ahead buy it.. common problem on this - Inverter board -
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Have a friend who owns a 50 in Sanyo plasma tv.
If you have a part number for the board this place could carry it. They sell thousands of parts for tv's. check it out www.shopjimmy.com
Posted on May 08, 2009
Anonymous
  • 1077 Answers
SOURCE: Sanyo DP15647 powers on but no display, trying to find fault
I had a similar problem like yours with a different TV. I had to find the Service Manual for the TV to really find the problem. The manual gives me every schematic and parts number list for every board in the TV. It turned out to be a bad Inverter Transformer. It was one of six that powered the LCD screen. You might have the same problem.
The Service Manual on the internet for most TVs are under $20. It's the best material for diagnosing the problem. It worked for me.
Posted on Jul 15, 2009
Anonymous
  • 92 Answers
SOURCE: 50 inch Sanyo Vizon Plasma TV. Has sound but no
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Posted on Sep 06, 2009
Testimonial: "Thank you for your response. We were driving ourselves nuts - fuzes checked out fine and not other guess where to turn. We appreciate your help!"
Anonymous
  • 34 Answers
SOURCE: hi i have a 50 inch sanyo plasma tv...all of a
Usually a power issus are a power suppy issue or main board issue. If unit or pilot lights do not light happens.
Posted on Nov 08, 2009
tvhelp-Dave
Shukai Fung
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
2answers
Where is reset button on sanyo 50 inch tv model DP50740 The TV will not stay on
There is no reset button on televisions. I see that is a plasma set, if you are just losing the picture that is one thing, if the whole set is shutting down, that is another. Please advise
I own a 50 inch Sanyo modelo DP50740 it turns on the only problem is that the buttons on TV don't do anything and the controller doesnt do anything as well please help
Check and replace the main system control memory I. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
I have a Sanyo DP50740. Had about 2 years. All of a sudden it started shutting off after turning on. Will not turn on again until unplugging and plugging back in. Then it shuts off again right away. Could...
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
It clicks on then clicks off
It sounds that the TV switches ON, and switches OFF, after three relay clicks. It is likely to the fault to its main board. Contact any service technician. This is not a user repairable fault.
google.com/+GopakumarGopalan
We were just watching tv and it just shut off. Now it won't turn back on. I already unplugged it and still nothing except for the green light will come on for a second then turn right back off. You can...
Now tv on,power LED light indication flashes?Yes.The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
What cable do i need to connect my laptop to my Sanyo DP50740?
Hello jaygee7414,
Sanyo DP50747 not support for D sub conection (PC in).
To connect PC in, you can use DVI or HDMI input.
Some Laptops already have HDMI or DVI out put. Like HP mini, sony vaio.
Or you can use s-video input.
Thanks.
Hi i have a 50 inch sanyo plasma tv...all of a sudden the tv turned off and never turned back on no power nothing plz help
Sanyo DP50747 50 in. Plasma TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
