It got off automatically,,,,
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: hi this is srinivasarao, i
Welcome to FixYa! There's a possibility that the driver is not properly installed. Please follow these steps for you to be able to make it work as long as its not a hardware issue. Please click on this link to download the latest driver for the camera.
1. Click download at the bottom of the page.
2. Click on I agree.
3. Click on Run.
4. Click on Run again.
5. Follow the download instructions. Once done, press Fn Esc on the keyboard for you to be able to disabled/enabled camera.
Hope this information will help. Thank you for using FixYa!
SOURCE: I bought a lenovo ideapad z560 for my sister in
Welcome to Fixya
It could be software problem. Try to restore the computer back to the factory state. Turn off the computer then press the small button located beside the power button then follow to on-screen instruction to restore it from initial state. By doing this, we will now clear any software issue in the computer since it will be restored from the date it was purchased. If same thing will happen after restoreation then you need to send in the computer to depot repair depatment for keyboard replacement. I believe the computer is still under warranty. You may call 18774536686 then press option 2 for hardware support/repair.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: hi this is abhi.my lap
hey just download the fresh new audio driver from lenovo site and install and when it asks overwrite the existing ,then click on no to all button
