Question about Sharp Office Equipment & Supplies
My Printer is displaying an H4 error
Sharp AR 5516 Photocopier
Posted by Mandy Mutonga on
Chris Coughlin
  • Sharp Expert
  • 1,326 Answers
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Posted on Oct 07, 2012
5 Related Answers
roytardio
ronald tardio
  • 106 Answers
SOURCE: my sharp AR 5516
fuser problem
Posted on Nov 20, 2011
Anonymous
SOURCE: sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Posted on Aug 25, 2010
SOURCE: My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Thanks
Tareq
Posted on Aug 13, 2009
Xzx Cxc
  • 4 Answers
SOURCE: Problem for Sharp AR-5320 Black
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Posted on Aug 22, 2010
Rick Kasper
  • 2072 Answers
SOURCE: solution TO sharp photocopier ar-5516
Normall on an sharp machine, You press # * C * and that will enter diagnostics. Then you enter 14 , then 1, and press start. It is the procedure to reset an H4. Works 99 percent of the time.
Posted on Oct 06, 2010
My photocopier sharp AR 5516 is showing H4, what is the solution?
There's an earlier response to this question on fixya in Dec 4, 2012. Search "sharp ar5516 error code h4". It's the third hit down.
Jul 09, 2015 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
Jun 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
Solution TO sharp photocopier ar-5516 4 H error
Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button.
Oct 06, 2010 | Sharp Office Equipment & Supplies
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Sharp ar 5516 printers error h5. h4
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Dear sir
Thanks
Tareq
Aug 12, 2009 | Sharp Office Equipment & Supplies
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
536 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
