Question about Carrier 38CKC030 Air Conditioner
Screen is blank, buttons seem to do nothing. Furnace, however, does continue to run - you just can't change the temp. It appropriately cycles on and off. This new thermostat is non returnable so can someone point me in the right direction please? Thanks!
SOURCE: Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Posted on Aug 27, 2007
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
SOURCE: Carrier thermidistat screen went blank
Check the battery in the thermostat it is dead!! Should be 2 AA batterys!
Posted on Sep 12, 2009
SOURCE: blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Posted on Dec 03, 2009
SOURCE: Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Posted on May 06, 2010
Mar 13, 2017 | Carrier Heating & Cooling
Jul 19, 2015 | Carrier Heating & Cooling
Mar 22, 2012 | Carrier Heating & Cooling
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
May 10, 2010 | Honeywell Programmable Thermostat Heater
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Sep 11, 2009 | Carrier Heating & Cooling
Jul 01, 2009 | BenQ FP71G+ 17" LCD Monitor
Apr 11, 2009 | Shaw Robert RS-9420 Thermostat
Jun 23, 2008 | Carrier Heating & Cooling
98 people viewed this question
