SOURCE: No coffee is coming out of the machine...
There may be a blockage in the electrovalve but more information needed 1st. Can you get any water out of the frother spout? If you can it will not be the electrovalve.
SOURCE: Lots of disturbing noises, no coffee
It is is easy, if you know how to do it... as always
First take of the wather, trach bin etc,
Start with removing the cup wher the beans is stored, the adjustment knob for the mill is a tricky part. Remove it by bending out the side of the knob. Thereafter remove the screws from cup and those you on see on the top.
The front (silver frame) is removed by lifting it upwards, behind it you have 4 screws that has to be removed.
The last two screws is found under the wather tank.
Now you should had take away 11 screws, at least...
Bend the back of top and it will be off. Finally push the rest of the plastic cover backwards.
Do you know what the error codes says? I have know 6,8and no coffy...
SOURCE: Krups XP7240 leaks
The grind selector knob can be removed with the following steps: 1) Remove screw on side near grinder (do not let the screw fall into grinder, :-) ), 2) use sharp knife or similar to pry off cover with three dots. This should be easy. 3) Now you can rotate the grind selector and see that the white clear plastic does not rotate and the black does. There are two little pieces (one black, one clear plastic) on opposite side from grinder that slide over eavh other to keep this knob 'locked' into place. 4) again with a sharp pointed knife or similar you can separate these two pieces to 'unlock' them. This is made easier by lifting the side of the bean holder by the grinder gently and tipping it up. Be careful not to force anything too much. The black part should pop off. 5) Now you can lift off the clear bean holder.
After this good luck. We made it farther into the machine, but could never get to where we needed to go to fix our problem.
Krups must be congratulated for designing a machine that cannot be repaired and must be replaced with new purchases.
SOURCE: Krups XP9000 fully auto unit will no longer grind
Perserverance...it's cheaper.
Also found a limit switch which i think is thermal so once removed the grinder is operational again!
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
