Your nailer uses 18 guage straight nails, from 5/8" to 2" long. As long as you meet these requirements it doesn't matter if they are basic bright, galvanized or staniless nails. If you Google or Bing search "18 guage stainless steel nails" you will find several mail order places that carry the nails you need. Not very many places carry stainless steel nails in stock because of their cost. Unless you live in an area where their use is predominant you will have to order them.
SOURCE: air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
SOURCE: How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
SOURCE: will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
SOURCE: nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
18 ga 1 1/2" - 2"
