Question about Simplex Kaba Ilco Unican 1000 keyless lock
How can i remove a unican lock
I need to change the lock to a new door and dont know it comes apart.
Posted by bob riedel on
Coaltowner
  • 963 Answers
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Oct 05, 2012
5 Related Answers
Frank Mangiapane
  • 36 Answers
SOURCE: i need to change the code on my unican ll1011
Copy this address into the address bar on your web browser http://www.tharstonconsultancy.co.uk/html/body_code_change.html You will find detailed instructions for the change. Please rate this answer,thanks.
Posted on Apr 11, 2009
Anonymous
SOURCE: lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
Posted on Jun 26, 2009
Stanley Runyon
  • 57 Answers
SOURCE: How do I remove a
Inaert the pointed end of the spanner wrench into the hole in the lever hub (you may need t tighten up the rose temporarily to expose the hole), and depress a retainer to release the lever.
Once the lever is off, remove the two screws that were exposed when you removed the control cylinder and plate,
the lock should come off the door at this point.
Posted on Jan 06, 2011
Coaltowner
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Good Luck!
Posted on Mar 06, 2011
Anonymous
SOURCE: I have a Unican 4000 series electronic door lever
Unican 4000 factory-default master code is 12345678
Posted on Mar 08, 2011
2000 buick century door wont open
Use a Slim Jim to pop the door open or have AAA do it for you. Once open take apart the interior side of the door to gain access to the door lock mechanism and reattach the control rods for the lock with new clips.
Jul 16, 2014 | 2000 Buick Century
How do I replace parts on the door of the GE Profile Advantium 120 Microwave
the door will come apart so you can screw it in from the inside its pretty easy just lay it out so you dont lose parts same with the clips they shoud either snap in when you have door apart or screw it in its just time consuming and terious work buy its do able
May 01, 2012 | GE Profile Advantium 120 Wall Oven
I own a second hand 1999 VW Golf MK4 19 TDI and I have been experiencing trouble with the central lock for ages ! At the beginning the passenger side door when I pressed the lock button on the FOB key did...
Dear sir, I am glad to share the experience. I had the same problem. At first I also thought it was the key that was faulty, I Went and bought new batteries, but it never worked. When a specialist checked, we found that the ignition system is the one that was faulty. When we replaced it (USD500.0), the problem was resolved.
The only complication is that when you change the ignition system, the key and the steering lock which is always a set has to be replaced, the key need to be programmed with the computer in the car so that it works. So I wish you the best. Julius ouma, Kampala, Uganda. [email protected] gmail.com
Feb 10, 2011 | 1999 Volkswagen Golf
Truck has a new battery. When you open the door the door and dome lights come on. when you put the key in the ignition and turn to run position the gauges come up. When you turn to the start position all...
dont think this is a battery cable problem but more like the igntion switch on the back of the steering lock ,try taking the shroud off and then use a meter to find the feed and then turn ignition on as the dash lights work then jump it across from the feed to the starter wire connection and if it works then you know you need to change the electrical switch .easy when you apply some logic
Jan 27, 2011 | Ford F-150 Cars & Trucks
The rear access doors will not unlock on our 04 Suburban, not with a key or the buttons. All other locks work fine.
ok it sounds like the linkage has came off. You will need to crawl to the back and remove the door panel inside you will see a rod that goes from the key location to the handle this rod has bushings that can wear out change the bushings and place the linkage back in and this should fix your problem.
Dec 12, 2010 | 2004 Chevrolet Suburban
My 1993 Jeep Wrangler drivers side door will not open from the outside. Do I need a new door handle? The lever moves but it doesn't open the door. I had a 'so-called' mechanic take the door apart to fix it...
the door lever is attached to the lock by a piece of wire with clips,it is a ***** to get to but once the inner door panel is off, with the window up,you should be able to see the fault,(if its the lock itself,that can be replacd on its own,you DO NOT NEED TO REPLACE THE WHOLE DOOR (nice try,to make a few bucks though)more importantly, pass the word around about this "artist".
a dealer will take about an hour to sort out this problem....
Jul 31, 2010 | 1993 Jeep Wrangler
If i change my ignition after a break in do i need a new key for the doors and ignition too
If the door lock is undamaged then it's fine to use the old key in the door and the new key with the ignition - you then have 2 separate keys for ignition and door -
I dont quite understand the question... could you word it fidderently,
You said you "changed my ignition" - which parts of the ignition?
Jan 22, 2010 | 2000 Nissan Xterra
I need to change the lock in my drivers side door
first with the L/F window lowered, remove the door trim. Before disconnecting window switch, raise the window all the way up . Now, look inside the door to where the lock cylinder is. You need to unclip the attached linkage to the lock cylinder. Remove "C" clip, ( careful you don't damage outer door panel ) securing cylinder to door and remove lock.
Apr 05, 2009 | 1989 Chevrolet G20
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
544 people viewed this question
Top Simplex Locks & Locksmithing Experts
JonSnell Electronic
JonSnell Electronic
Chris Walker
Chris Walker
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
