No power, green blinking light
Just fixed that exact problem on mine and made a video on what part and how to replace it. I also added a link below for the part I bought. L5973D STMicroelectronics Mouser
How you been check already if their is a bulging capacitor in the power supply board?
SOURCE: Philips 42PF7220A/37 Red Light blinks 5 times in a row
After a lot of research, I have been able to locate the part which in my Philips 42PF7220A/37 Plasma TV appears to be the problem. I found out that heating and cooling certain parts of the board(s) allowed me to get beyond the 5 flashes error message and power up the TV. Through a process of elimination, I narrowed it down to the SSB Tuner board 3104-313-60376, This board is located behind the board covered with the shield. The specific component in question is the one I have circled in red on the attached photo. It is a crystal Xtal 27 mHZ 18Pf PART# 2422-543-01397. When I spray this component with cold air (freeeze) for a couple of seconds and then plug the power back in the TV will go through it's initialization cycle and turn on. It may turn off automatically, in which case, you just power it back on either manually or with the remote. It has now been 7 days, and it hasn't failed since. I have NOT replaced the part, if it fails again, that will be my next step. The part is about $ 10.00. The entire card can be purchased for about $ 100.-
I am reluctant to do anything further, because I'm not positive that the component is the problem or possibly the input to it. What I do understand is that a crystal can be excited (turned on) by either heat or cold. Perhaps it was stuck and spraying it with cold and heat released it. In any event, the TV is working for now. Hopefully it will stay this way.
If anyone can shed some light on why this may have happened, I would appreciate it.
SOURCE: Philips LCD TV - Red blinking lights
I would check the capacitors on the power pack for failed or blown ones. doing this work will require soldering skills
FYI
SOURCE: 47" Philips LCD TV will not stay on and show a picture.
Your mainboard needs to be replaced.
You can get one on ebay and replace it or get someone who can do that for you.
if you still have guarantee, it is covered, if not you will need to buy it.
SOURCE: RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
SOURCE: red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
