You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
SOURCE: dell latitude password bios forgotten
Hi, The only way for that is to contact dell support. you're gonna need help from a level 2 tech from austin as they're the only one who has the master password for that.
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
SOURCE: I have forgotten my laptop bios password
-rate if it helped you.
SOURCE: remove or reset dell latitude
How to reset The Latitude C640 Bios password?!
1.First flip your laptop over and remove the battery, as well as any cables connected to the laptop.
2.Remove the screw latched into the memory panel on the bottom of the computer found near the rear.
3.Lift the panel off and expose the memory modules.
4.Seek for a small push-button and press it, holding it for about two seconds. Reassemble your laptop and start it up.
Thank You!
