SOURCE: burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
SOURCE: Motor/Fan does not run. I have removed and taken
Sorry to read about your problem, I hope this helps you out.
Well you can order a new motor at shop vac, check out this link.
you dont have to remove to check the motor, just connect power to the motor leads
www.shopvac.com/support/
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
