Question about KLH DVD8350 DVD Player
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
Vizio TV has 5 RCA jacks associated with Component video/audio input. I connected Red/Green/Blue cables from DVD output direct to Component video input of TV. I connected Red/White cable (audio) from DVD to Audio input on TV. I turn on TV and select Component input and I get blue screen with "No signal" message.
I cannot locate KLH manual to see if there is something required in setup to initiate ? a component output? Can someone help me with this please? Thanks, Tom.
Posted by TxTomT on
Randy Constan
    New Friend:
    Problem Solver:
  • 15 Answers
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Posted on Jun 02, 2017
2 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: Recording from VHS to DVD
Appreciate the direct "Ask Me".
To my knowledge, a KLH DVD8350 is only a player, it has no recording capabilities, sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
Anonymous
SOURCE: KLH R7000 Component Video Problems
I have lost my remote and instruction book where? do is it worth it replace
Posted on Apr 05, 2009
Is there an illustration for hookup of cables on the KLH DVD8350 DVD Player to an RCA LED HD TV?
all you need to do is match the cable type of the DVD to the TV and set the input on the TV to the same type be it HDMI or rca cables
Jan 30, 2016 | KLH DVD8350 DVD Player
Mirror display
If your are referring to the image (reverse video, ie, every one is left handed, wording on ticket tape backwards etc.) on your TV, the problem is in the signal board. Generally unplugging and plugging in the TV will not reset the TV. Just repaired a TV with mirror image. You will need to replace the signal board. The signal board has all the rca component jacks, hdmi, audio, and the RF connection for cable or over the air signal. Thanks for asking me.
May 25, 2013 | Vizio L32 32 in. LCD HDTV
When I plug my PS2 or VCR into the back of my TV using red, white (audio), and yellow (Video) cables, the picture is grey and fuzzy. I have plugged the yellow into the far left port marked "Y". I...
Yellow is a composite output and should be plugged into a composite input, whereas Y indicates the COMPONENT input of the TV. If you don't have a separate composite input use a scart to phono (rca) adapter in your tv's scart input.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Mar 04, 2011 | Insignia 42" LCD Flat-Panel HDTV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
PANASONIC HOMETHEATER SYSTEM TO PLASMA TV
Some where on the back, bottom or sides of your plasma tv you will find input jacks for the audio and video. You must know what type of inputs you want to use.
Most have have 4 types
HDMI (audio and video signal combined)
Component (red, blue, green RCA jacks for video only)
Composite (yellow RCA jack for video only)
S-video ( larger round black jack with video only)
The Panasonic should have all of those also. I am certain it has HDMI and Component.
Connect the HDMI cable into the output HDMI jack from the Panasonic into the HDMI input jack on the TV.
Then using your remote for the TV make sure you select the HDMI input for viewing.
If you use any of the other video outputs on the Panasonic just connect it to the same type of input jack on the TV. Once again check the owners manual for more detailed instruction if you need them.
You must always be sure to have the proper input selected on the TV to be able to view it.
You can also respond back with more questions if you have any.
I am happy to help.
Dave
Jun 27, 2008 | Audio Players & Recorders
KLH R7000
Nope. That's the coaxial digital audio input. Thats the one to use for your dvd players digital audio output.
Jan 29, 2007 | KLH R7000 Receiver
KLH DVD8350 DVD Player Logo
108 people viewed this question
Top KLH Televison & Video Experts
ray gallant
Tom Chichester
Are you a KLH Televison and Video Expert? Answer questions, earn points and help others
