Question about Radio Shack TRC-447 CB Radio
SOURCE: Radio Shack TRC-502 cb radio
Here is the owners manual I'l see if I can get my hands on a internal schematic
http://support.radioshack.com/support_electronics/doc62/62220.pdf
Posted on May 14, 2008
SOURCE: Radioshack TRC-503 CB radio
First, use an ohm meter and test the power wires for continuity. If they test good then there is a protection diode on the board that is probably blown. If I remember right it is a 1N4001 diode. Generally you can see if its blown as it will either be burnt or look like its cracked. If it is you will need to replace that diode to restore power.
Posted on Aug 28, 2009
SOURCE: I was wondering what was the range for the
Antenna :
-should be tuned, have good coax with no pinches, whip is centered over highest flat metal surface, no metal beside adjacent to whip, power is wired to battery direct, not to ignition or cigg lighter. whip is wiped clean of corrosion, whip is up, longer is better.
Praire City car-to-car: 15-20 km's
Praire Rural car-to-car: four-thirds over the horizon. Probably 60 km's.
Alot further over water.
Less within trees and mountains/valleys.
Google "Ham radio" & "ducting" "inversion" "skip" "sun-spots"
these refer to a condition where a radio signal getting stuck between the upper and lower atmospheres and travel intact for 1000's of km's (canada to mexico for example)
Posted on Sep 06, 2009
SOURCE: Where can I get a circuitboard schematic for my
Try the radio shack website.
They have some service manuals that you can download.
Best of Luck!
Posted on Apr 12, 2010
Aug 30, 2014 | Radio Communications
May 14, 2008 | Radio Shack TRC-503 CB Radio
Sep 28, 2012 | Radio Shack Modifications Document...
Oct 18, 2011 | Radio Shack TRC-447 CB Radio
Oct 14, 2011 | Radio Shack TRC-447 CB Radio
Mar 17, 2011 | Radio Shack TRC-447 CB Radio
Dec 28, 2010 | Radio Shack TRC-447 CB Radio
Mar 11, 2010 | Radio Shack TRC-503 CB Radio
Sep 28, 2013 | Radio Shack TRC-447 CB Radio
Aug 03, 2013 | Radio Shack TRC-447 CB Radio
485 people viewed this question
