Ways to hook up an equalizer
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
SOURCE: hi i have a yamaha rx-v995 reciver and just
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
SOURCE: I have a Yamaha HTR-5890 receiver and I am trying
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
SOURCE: how do I connect my xbox 360 to my yamaha HTR 6230 receiver?
Use HDMI because they combine picture and sound in one convenient cable. You can buy the cheapy ones because they work the same as the pricey ones with no degradation in sound quality or picture.
SOURCE: would I be able to
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose some form of STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
