Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
My friends have a Fisher and Paykel Dish Drawer, Model# DS605SSFPUS, that will not cycle through a full wash cycle. In standard wash program "Normal Wash" the unit gets stuck at around the 58min cycle point and then has to be advanced manually to finish wash cycle. They say that they have left their home before and forgot to turn it off and it stayed on for 3hrs. When they got back a F4 error code was flashing on digital display. I know that the F4 code means a faulty temp sensor but I would like to know if replacing this sensor would solve the problem or if the problem would arise again in the future because there is another faulty component in the system like maybe the electronic control board. Any advice on how to proceed with this repair would be greatly appreciated. Thanks in advance! Ryan
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Posted on Sep 13, 2013
SOURCE: u3 code on fisher paykel dishdrawer how to reset?
This site tells you how to reset:
http://applianceguru.com/forum1/163.html
I have the same issue and will try this tonight to see if it helps.
Posted on Feb 18, 2009
SOURCE: F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
Alternately, should you have the two-drawer, open any drawer and look at the wash
intensity/economy buttons. Now press them, one at a time,
alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 15, 2008
SOURCE: Top drawer Fisher & Paykel Dishdrawer no lights lcd
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
Posted on Dec 11, 2008
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
Just had the same problem, removed the excess water from the drawers, turned off the power, removed the bottom drawer by pushing in the lugs at the bottom of the drawer where it butts up to the drawer front and pulling out the drawer. Then had to mop up with 4 t-towels and half a roll of kitchen roll the water in the bottom of the machine housing. The water gets into the electronics at the rear of the housing and obviously warns you of this by the F1 code?. I removed the white cover over the electronics with a screwdriver by pushing it into a slot then sliding the cover across to the right, it is indicated on the cover how to remove it. I also then removed the screw on top of the PCB (printed circuit board) and lifted up the grey plastic base and wiped under that and the under side of the PCB. The PCB unclips on the left hand end of it and lifts out, try not to pull the cables out though. I then used a hair dryer as suggested by someone else on here to dry out any excess that you could not wipe dry, my daughters Hello Kitty hair dryer didn't last long though, she's not impressed! So try not to stick the dryer right in the housing to avoid overheating it. About 5 minutes did the trick for me, then re-assembled everything, turned it on and hey presto! It worked!!!! Its not that hard, good luck!!!
Posted on Oct 27, 2009
