How do i change my phones off silence, I held down the number key until the message tells me that silence is on but i can't figure out how to make the change with out putting in hw many hours i wa
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
near as i can tell you can't silence the answering machine. i wanted to do the same thing. it's either on or off but u can't downsize the volume to complete silence.
Hello and Welcome to FixYa!
The easiest way is to press and hold the HASH (Number sign key : #) when you are at the home screen. A 'Phone Silenced' message will pop-up indicating that its done.
Wiqi
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
If the message "Check Operator Services" appears on the screen of your mobile when you attempt to make a call/sms, you should:
Check if there's a number 2 on the left hand corner of your screen.
If so, press and hold the # (hash) key until you see the message "Change the Phone Line?".
Press OK. The message "Line 1 selected" should then appear and the number 2 will disappear.
Attempt to make a call.
Note: Line 2 is an option on Nokia mobiles that's selected by holding
down the hash key and pressing OK. Vodafone doesn't support this
feature. You can prevent accidental changing of lines by activating your
keypad lock. On some handsets, you can do this by pressing "Menu" then
"*" to lock the keypad. "Menu" then "*" will unlock.
when u hold down the starr key or the volume key it activates silent mode all u have to do is press down the starr key until it beeps at you then u r out of silent mode
-Dial into voicemail -Enter password to access system -Press button for Greetings or Administrative Options menu -Choose type of greeting -Press button to change it and record new greeting -Listen to new greeting and press button to confirm -Exit system
