fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE:
http://en.wikipedia.org/wiki/Parallel_ATASATA:
http://en.wikipedia.org/wiki/Serial_ATARegards,
joecoolvette
