It starts and runs OK, correct?
Check your fluid level - Directions in the Owner's Manual.
Are you pushing the brake pedal b4 trying to move the lever (sorry, have to ask)?
Does the lever move @ all? Into Neutral?
Is the Check Engine Light on?
Sounds like you'll need to have it towed to a shop. Call the Better Business Bureau for a reference, or recommendations from family/friends.
GL,
Td
SOURCE: Removing 05 Nissan Altima Drive Axle
YOU NEED A HAYNES REPAIR MANUAL.IT HAS PHOTOS TO SHOW YOU HOW TO REMOVE DRIVE AXLE.
SOURCE: how do i reset the odometer on the 2007 nissan altima
PUSH AND HOLD BUTTON IN SPEEDO CLUSTER. FIRST SET TE SPEEDO TO READ ODOMETER THEN PRES AND HOLD BUTTON.
SOURCE: 2007 nissan altima fuel filler release button
Try having someone push in/out slightly on it while you trip it.
SOURCE: 1994 nissan altima blowes fuse to dash panel when
seems like you have a short somewhere take it to a machnic they may pin point it with a diagnostic cable
SOURCE: 2005 nissan altma won't go
I have seen this problem before. Frist thing is do you have a test light and seond thing is how comfotable are you with taking part of your dash apart? You might need a control unit in the upper portion of the instrument cluster.
