Question about Microsoft Windows XP Home Edition for PC
Logon Change Does anyone know how to change the appearance for XP home? I want it to show the screen from Windows 2000, where you have to type in your USERNAME and password. Thx.
Posted by Albert Zeller on
Brian Sullivan
  • Microsoft Master
  • 27,725 Answers
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Posted on Oct 03, 2012
4 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: Windows logon for XP professional- password?
Hello!
With THIS program you can change remove or delte password on winxp.This is bootable cd just burn it to cd and start pc with CD-ROM!
Posted on Jan 05, 2008
pagebor
Rajkumar Bordoloi
  • 2785 Answers
SOURCE: forgot the username and password for my windows xp admin account
try to boot in safe mode and remove the password
Posted on May 09, 2008
Computer Links
  • 2386 Answers
SOURCE: My PC is asking for a password if I logon
if your computer on network then it must have some domain name and password, otherwise change setting to workgroup.
Posted on Feb 24, 2009
Anonymous
  • 41 Answers
SOURCE: windows vista logon password
There is a way you can log on bypassing the password although there is a password set.
here's the fix
Go to start > run > type control userpasswords2
uncheck the box that says user much enter a user name and a password to use this computer, then select the account which you want to login automatically, click apply, it Will ask for the user name and the password, fill both and you are good to go. next time you start your computer it will automatically log into that account..
Hope this helps..
Regards,
Anup
Posted on Apr 07, 2009
How do I logon as administer
The built-in Administrator account is hidden from Welcome Screen when a user account with Administrator privileges exists and enabled. In Windows XP Home Edition, you can login as built-in Administrator in Safe Mode only. For XP Professional, press CTRL + ALT + DEL twice at the Welcome Screen and input your Administrator password in the classic logon window that appears.
To have the Administrator account displayed in the Welcome Screen, try one of these methods:
Method 1: Using TweakUI Power Toy for Windows XP Download TweakUI from here: v2.00 for Windows XP | v2.10 for XP SP1 and above
Open TweakUI and click "Logon" option in the left pane. Put a checkmark against the option "Show Administrator on Welcome Screen". Click OK to close TweakUI. Logoff and see if Welcome Screen lists Administrator login. Changes are immediate and you can use the Winkey + L to switch back to Welcome Screen to see Administrator account is listed.
Use this procedure to hide/unhide any user account from the Welcome Screen. Please remember, you can still login to a hidden account using CTRL+ALT+DEL classic logon method, but cannot Fast User Switch to a hidden user account.
Method 2 - Manual registry edit
  • Click Start, Run and type Regedit.exe
  • Navigate to the following key:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon \ SpecialAccounts \ UserList
  • Use the File, Export option to backup the key
  • Create a new DWORD Value named Administrator
  • Double-click Administrator, and set 1 as its data
  • Exit the Registry Editor.
For Windows XP Home Edition While you can configure Windows XP Home Edition to show Administrator account in the Welcome Screen, you cannot login as Administrator in Normal mode. Visit the following link for more information:
Error Message: Unable to Log You on Because of an Account Restriction
Please post your feedback and Vote if the problem resolved as per your satisfaction.
May 20, 2010 | Computers & Internet
Tip
Methods to reset your Windows XP password
There is nothing to worry if you forgot your Windows logon password or if your password expires. You can reset your Windows password by following instructions given below.<br /><br />You cannot reset password unless you have reset disk or can log on as an administrator. You may need to reinstall your operating system before using computer again. This is an essential safety measure setup by Microsoft Windows. Without this, anyone could change a password of anyone's computer. <br /><br />Reset Windows XP Home Edition Password<br /> <br />There are two methods to reset Windows XP Home Edition password<br /><br />First Method: <br /><br />To reset password you may need to log on as an administrator. Follow steps mentioned below to log on as an administrator <br /><br />a. Reboot the PC.<br />b. Press CTRL+ALT+DELETE couple of times, and then type the name of the administrator user name or just type 'Administrator'.<br /><br />c. Type your administrator password in the password field, and click OK. If you do not know the password, leave it blank, and click OK. <br />d. Press Start button on the taskbar, and click Run.<br />e. Enter control user passwords 2, and click OK button.<br />f. Open Users tab, select the user account form the list that you want to reset the password for, and press Reset Password.<br />g. Select a new password and Enter it in the new password field and then type that password again in the confirm password field, and then press OK.<br />h. Reboot the PC, and try logging in to the computer. <br /><br />If your computer is a member of a domain then follow these steps:<br /><br />To log on to the window as an administrator: <br /><br />a. Reboot the PC, and press the F8 key during the boot until the Windows Advanced Options menu appears.<br />b. Select the Safe Mode option, and press ENTER key.<br />c. Select Microsoft Windows XP edition, and press ENTER key. <br />d. Click your user name screen button, then click Administrator, and enter the administrator password in the password field.<br />e. Press ENTER key, and click Yes. <br /><br />To reset the Microsoft windows password:<br /><br />Click Start button on the taskbar below and then click Run.<br /><br />f. Enter control user passwords 2 in the text field, and click OK.<br />g. Pick the logon user name for which you want to alter the password.<br />h. Click on Change the Password, and enter a new log on password. <br />i. Press Change Password button.<br />j. Reboot the PC, and then log on to the windows. <br /><br />The Second Method: Using a password reset disk<br />To log on to the computer by using a password reset disk, follow the steps outlined below. <br /><br />Reset password for Windows XP Professional Edition<br /><br />1. Reboot your PC.<br />2. Click the user name, you'll see an error. <br />3. Click on the Use your password reset disk. The Password Reset Wizard window will open.<br />4. Click Next.<br />5. Insert the password reset disc into the CD/DVD drive, and click Next.<br />6. Type a new password and confirm the password in the required fields, then click on Next.<br />7. Click Finish, log on to the PC again. <br /><br />
on Jan 18, 2011 | Computers & Internet
Tip
Hack windows
Here are the steps involved to <b>Hack</b> the <b>Window XP Administrator Password</b> .<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32</li> <li>mkdir temphack</li> <li>copy logon.scr temphack\logon.scr</li> <li>copy cmd.exe temphack\cmd.exe</li> <li>del logon.scr</li> <li>rename cmd.exe logon.scr</li> <li>exit</li></ol> Wait its not over read the rest to find out how to <b>Hack</b> the <b>Window XP Administrator Password</b><br /> A Brief explanation of what you are currently doing here is<br /> Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called <b>mkdir. </b>After which you are copying or backing up the <b>logon.scr</b> and<b> cmd.exe</b> files into the <b>mkdir</b> then you are deleting the <b>logon.scr</b> file and renaming <b>cmd.exe</b> file to <b>logon.scr</b>.<br /> So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an <b>unprotected dos prompt without logging in</b>. When this appears enter this command<br /> <b>net user password</b><br /> Example: If the admin user name is clazh and you want change the password to pass Then type in the following command<br /> <b>net user clazh pass</b><br /> This will chang the admin password to pass.<br /> Thats it you have sucessfully <b>hacked</b> the <b>Window XP Administrator Password</b> now you can Log in, using the <b>hacked</b> <b>Window XP Administrator Password</b> and do whatever you want to do.<br /> Here are the steps involved to De <b>Hack</b> or restore the <b>Window XP Administrator Password </b>to cover your tracks.<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32\temphack</li> <li>copy logon.scr C:\windows\system32\logon.scr</li> <li>copy cmd.exe C:\windows\system32\cmd.exe</li> <li>exit</li></ol> Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click <b>Yes </b>to overwrite the modified files.<br />
on Dec 24, 2010 | Computers & Internet
A computer expert change my admin password. how I break that password
Here are the steps involved to Hack the Window XP Administrator Password .
  1. Go to Start –> Run –> Type in CMD
  2. You will get a command prompt. Enter these commands the way it is given
  3. cd\
  4. cd\ windows\system32
  5. mkdir temphack
  6. copy logon.scr temphack\logon.scr
  7. copy cmd.exe temphack\cmd.exe
  8. del logon.scr
  9. rename cmd.exe logon.scr
  10. exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
My welcome screen is not appearing what i hav to do???
Hello
You need to change the way user's log on. I'm assuming you have windows xp?
Is so, go to the control panel and then click on the "users" icon. the option to change the way user's logon, put a check mark where is says use the welcome screen option.
Please do let me know if this solves your problem. thanks.
Feb 22, 2009 | Microsoft Windows XP Professional
I'm cannot logon to WindowsXP Home Edition
Windows stores the activation information in two files in the c:\windows\system32 folder: Wpa.dbl and Wpa.bak. If those files are locked, or permissions are incorrect, Windows may not be able to save its activation information.
You might also want to check the following registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFTNT\CurrentVersion\Winlogon
(change Activation Required value to zero)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion
(change RegDone value to 1)
Boot into safe mode, click Start→Run and type regedit then check these values.
Jan 10, 2009 | Microsoft Windows XP Home Edition
Forgot password
Reboot the computer. Press and hold the f8 button. Select safe mode from the menu. You should be able to see the admin login. Then you can make the changes.
Nov 22, 2008 | Microsoft Windows XP Professional With...
Locked out from pc? forgot password? how to change password?
If you are using Windows XP Professional there is an Admin Account Hidden. Thats if it isnt the current one.
Start your computer and repeatedly hit F8 for boot changes, start in "Safemode" or "Directory Services and Repairs"
If the Welcome screen shows Hit Ctrl+Alt+Del twice to get classic logon screen then Type Admin and if there is a Password enter it.
If you do log in, you should have the ability to change the account Password or create new one.
If you are Using XP Home Edition then theres not much luck unless you can think of the PW.
Your Best bet is to Backup and Reinstall Operating System
Oct 07, 2008 | HP Computers & Internet
No rights to run control panel requires new instal need media
1. to gain rights do the following.
Sep 17, 2008 | Computers & Internet
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition for PC Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
