Question about Sony KP-46WT510 46" Rear Projection HDTV
Possuo uma tv kp51ws510 posso usar o stk392150
Stk392-560.....= stk392-150
Posted by adriano nascimento on
Edward
  • Sony Master
  • 3,459 Answers
No - stk392-560 can only be replaced by the same or a stk392-570
when buying replacements make sure they are not the junk generics...anything under 20.00 each are generics....the real sanyo versions are 20-40 each on average but worth it since they will last
Posted on Oct 09, 2012
Onde posso comprar este aparelho
No mercadolivre tem uma pessoa vendendo...
May 22, 2014 | Sony Ta-sa300wr Surround Amplifier...
Como posso fazer para ver uma imargem no computador feita pelo dvr.
you can try the windows media player or a aftermarket program you could get on the internet, NOTE: be careful to check programs you download for viruses before installing them.
Aug 23, 2013 | E-Machines eMachines Desktop PC
Kp51ws510 posso usar o stk392-150
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Oct 03, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Audio sparito compare cuffia come posso risolvere il problema?
Ciao.
Stacca le cuffie, stacca il cavo di alimentazione, aspetta 5 minuti, riattacca il cavo di alimentazione e riavvia la TV. Se non funziona , dopo aver staccato la corrente (dal cavo) prova a riavviare la TV con e senza cuffie, a volte questo sblocca il problema.
Se non funziona il prolema puo essere il contatto verso gli speakers. In tal caso le opzioni sono smontare e testare la TV o usare un sistema audio esterno collegato a jack della cuffia o meglio ai cavi audio bianchi e rossi.
Inizia a provare staccando il cavo della corrente, senza e poi con le cuffie inserite. Assicurati che la TV sia spenta prima di staccare il cavo.
Ciao e buona fortuna.
Ginko
Aug 28, 2011 | Televison & Video
Tenho uma placa de captura Philips SAA713x PCI TV Card ela nao funcona no Windows 7. Onde posso encontrar o drive compativel com Windows 7
Hi! Sorry, give it up, no one drivers work whit your card on windows 7. I tried a lot of that drivers but no one was correct.
Dec 27, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
