GPS not picking up satellite
SOURCE: problem with lx200gps meade telescope
It might be a voltage or electrical current problem. Make sure your DC power supply is between 12 and 14 volts. Make sure all electrical connections are tight. Where the power cord plugs into the connection panel, make sure the center pin on the panel fits tightly into the plug. It is a Radio Shack type "N" plug. If tou still have a problem, remove the bottom plate from the scope base and make sure all the connectors are properly seated on the circuit board. Check the connector on the end where the black and red wires are. That is a main power connector and if it is too loose it will not conduct enough current. There can be enough voltage drop that the drive motors won't operate, or they will and the scope will slew uncontrollaby. Be careful handling the wires so that you don't damage them. Good luck, Dave
Posted on Sep 26, 2008
SOURCE: Fist time alignment issues.
Did you calibrate the motors and TRAIN the drives? If not do these first--
During alignment the "alignment" stars may or may NOT be visible in the eyepiece-- CENTER the star. Once you do this with two stars your gotos should be good.
Posted on Mar 16, 2009
SOURCE: Calibrating & Aligning the Meade 10" LX200 GPS Telescope in the Southern Hemisphere
This makes sure that the scope is calibrated properly.
That's it!
You can also hold down the MODE key for about 4 seconds and scroll through the scope info. Make sure you have the correct location coordinates ( Lat/Long) and the correct time set.
Select a bright object first such as a planet and GOTO it. Once you have manually centered it in the eyepiece, press ENTER and hold it for 6 seconds, the handset will say " Press ENTER to sync", press enter and you have updated the scope with the coordinates of that object.
Posted on Apr 01, 2009
See Darth_Muppet response to same issue.
http://www.fixya.com/support/t1152604-calibrating_aligning_meade_10_lx200
Posted on Apr 12, 2009
Jan 16, 2014 | Tomtom GPS
Sep 26, 2011 | Garmin nuvi 1300 Car GPS Receiver
Mar 08, 2011 | Garmin nuvi 200W GPS Receiver
Sep 24, 2009 | Garmin nuvi 255W GPS Receiver
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Sep 16, 2009 | Garmin GPS 76 GPS Receiver
Aug 11, 2009 | Garmin eTrex Legend GPS Receiver
Jun 30, 2009 | Tomtom GO GPS Receiver
May 20, 2009 | Garmin nuvi 200W GPS Receiver
355 people viewed this question
