Question about Refrigerators
Condura refrigerator model# CT090SA
No cooling
Posted by efren laxa on
  • Timothy
    Timothy Jan 13, 2022
    Where can I buy a door rubber for condura refrigerator model CT 090SA
Michael
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Make sure you have 4 inches of clearance behind and side. Then check you condenser coil and clean any lint.. check your compressor is it running. Is your model a frost free model.. is your evaporator fan running.. is the evaporator frozen with frost
Posted on Jan 14, 2022
Location of drain pan of 2 doors Condura refrigerator it has bad smell
Look in the back of the fridge for the drain trough. The pan will be just above the compressor. The most likely cause of a bad smell though is something actually inside the fridge. Take everything out and wash it all down. It should be done once a year.
Error code P1 condura inverter
What means error code fr condura aircon
Condura inverter type air con indoor unit runs but when compressor motor start and runs then stop
First, I'm not a Condura Tech.
* Check your warranty. Call for service.
* repairs should be performed by a CFR certified tech.
*** Following is for information only ***
* Unit is short Cycling. Call your vendor.for service.
* Cycling with very little cooling or Hot air from unit can be caused by faulty valve or clogged system. Call for service
* Unit may need cleaning (after system check)
* Customer review; https://www.youtube.com/watch?v=cYjDbSMvGmY
* Final, Check your warranty. Call for service.
Aloha, ukeboy57
2answers
What does it Mean if there's a cf error code in condura Window type aircon?
That code means COOLING failure and could be a variety of problems from something as simple as a dirty filter to a bad compressor. More info would help me narrow it down
What's the original capacitor number use by condura aircondition model NG 070...
Ano po ang value ng compressor capacitor ng condura room aircon na ang model ay NG090DLX? Naerase nakasi ang number sa metal case ng capacitor .
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
