Question about Beverage-Air MT45 Beverage Cooler Commercial
Is It A Cooler or a Freezer?
I purchased a 3-door glass-front MasterBilt unit (used) from a guy on Craigslist. He told me it was a cooler and / or freezer. But, no matter where I set the thermostat the box termperature drops to 20 degrees or slightly less.
The box temp. has been around 40-50 degrees for the last 2 weeks probably because it was iced up. I would really like to use this unit as a freezer and not a cooler.
Last Friday I found the evaporator coil iced up so I called a local refrigeration tech out. He cleaned all the coils with a solution and told me to clean the evaporator fan blades. He put gauges on the compressor and the low side was running at 45 psi. with the box at room temperature (around 70 degrees). He said it didn't need refrigerant and it is running R12. He told me to let it run for a couple of days and see what it does. When I came in the store this morning there was ice on the side of the compressor and going up the line to the evaporator coil and I don't think the compressor EVER shuts off. I also cannot find a defrost heater anywhere around the evaporator.
I am thinking about replacing the thermostat but not sure if that is what's causing it to ice up. Here are the numbers that I found on the unit.
MasterBilt Model # BMC O
Thermostat #19-00903 -Technician said it looks like it's been replaced. This is a pigtail type thermostat that slides in between the coils of the evaporator.
Sorry this is so long, but hopefully someone can help me sort this out.
Thanks!
Posted by oxfordintmar on
  • oxfordintmar Dec 30, 2008
    UPDATE to cooler and or freezer?
    I called MasterBilt and they gave me an engineer who said the model # is BMG - 80. It is a mid-cool unit meaning the temp range is 34 - 38 degrees. So it is NOT a freezer. So that issue was solved.
    I also told the engineer about the compressor running all the time and he told me to replace the thermostat. I did that today and the unit is running perfect now. It's not icing up and it cycles off and on while keeping the temp at 36 degrees. I hope this helps someone in the future who has similar problems.
    Best
  • Northeast Cooling LLC
    Northeast Cooling LLC May 11, 2010
    If the unit is a freezer there has to be a defrost clock somewhere and it has to have heaters on evap coil and in or around the drain in unit. When a compressor ices up that usually means the coil in the unit is frozen as well. Give me more #'s off compressor and I can tell yu if it's supposed d to maintain medium temp, or low temp. this should help you. ;)
Dennis Boxerman
  • Beverage-Air Master
  • 1,303 Answers
With no heaters or defrost timer, it is most likely not a freezer unless someone removed all that. As best as I can tell, I can not find anything that equates to the temperature and pressures you related to. It could be either low on Freon or the R-12 has been removed and an alternate Freon installed to replace it. Hope this helps.
Posted on Jan 16, 2018
4 Related Answers
Anonymous
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
Anonymous
  • 6 Answers
SOURCE: Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
Posted on May 01, 2009
Anonymous
  • 614 Answers
SOURCE: beer cooler keeps freezing
Could be but sounds like it may be low on gas. What emp do you set it at. Should be about 35 degrees if you have it set to low it will ice up on you. Russ
Posted on Jul 22, 2009
Anonymous
  • 4 Answers
SOURCE: I have an older beer cooler. the fan costantly
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Posted on Jul 26, 2009
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
It is possible to take apart a Whirlpool wine cooler door to replace the tempered thermal glass unit inside. Door is stainless steel with plastic insert on inside with gasket in the plastic insert. I
It is likely a double glassed unit, You can try and slide a thin bladed knife like the snap blades between the glass and the rubber and cut it away., You may be better to take it to a glass company that make DGU (double glazed unit) and they will be able to produce another piece o glass for it and put it back through the machine to make it a new unit.
Aug 28, 2014 | Whirlpool 38-Bottle Wine Cooler
Why is my upright igloo freezer not staying close
The door sometimes warps and need to be lightly twisted back to where all four corners make contact and seal.
Your unit may need to be tilt back a bit so the door wants to close y itself, the front foot pegs are adjustable and can be turned to make the front higher or lower than the back side of the cooler, gravity closes the door when the unit is leaning back.
Aug 28, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
Is transmission cooler factory installed or an aftermarket purchase?
if it has a factory tow package usually it already has a trans cooler installed it will be located in front of the radiator/ a/c condenser , if not there not that difficult to install
Jul 07, 2014 | 1999 Jeep Cherokee 4WD
EVERSTAR COOLER HDBC36ID
Mine is 11 months old - pooling water on right (which is theside i keep colder for beer/soda/water), also my glass door on right has water between panes, I just called franklin (everstar) and they say a service guy will call in 5 days... I hope.
Did you get help and are you 'happy' with the service done?
Jun 22, 2009 | Franklin Industries FBC360D Beverage...
A Delfield Mdl 6151-S 2 door stainless freezer into a cooler? Change thermostat? It cost me $25 . Factory service says it's not practical. What is practical?
to do it right, you gotta get technical. Need to know the BTU rating of the evap coil. Then match the compressor/ condenser coil and the expansion device to the same BTU rating. Can prove to be somewhat expensive. Your unit probably has a 3/4 h.p. compressor. This is pretty big for a 2 door unit. Probably too big, but again, gotta get the technical on all that stuff.
Jun 03, 2009 | Randell 47 cu. ft. / 1331 liter Commercial...
Find locate of lighting ballast in 3 door BevAir cooler
Sometimes they are in the overheade space above the cooler .. if they were inside then they would have to be HO ballasts because of the temperature .. sometimes they are in the moulding strip under the lamp itself.
Feb 24, 2009 | Beverage-Air MT27 Beverage Cooler...
Magic chef wine cooler
That means couple of things. The cooler's glass door is poorly insulated, and the cooler is placed in a humid environment. To eliminate the sweating you can run a dehumidifier close to the cooler, or you can insulate the inside of the door with styrofoam but that's going to spoil the look of the cooler.
Aug 28, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
My 3 glass doors cooler
There are generally 2 reasons why this would happen. The defrost timer or heater has gone bad. Or, the fan is not working. Because you state that it runs all day long, I would think that the coils are now a block of ice and cannot cool. In any case, manually defrost it now. Turn off the power and use a hair drier on low (not hot) setting. This should fix the electrical cost for now. Then you can determine if the fan is running properly, or the defroster.
Apr 22, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Beverage-Air MT45 Beverage Cooler Commercial Logo
85 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
