Are you calling the oil pressure switch the oil solenoid ? The oil pressure switch could have failed which would push oil out the terminal where the wire is connected.
The 1999 and 2000 model years of the Ford Escort offered a limited performance edition ZX2 S/R which further enhanced the cars performance in every aspect. The 1999 has been tested as going from 0 to 60 in 7.6 seconds. if you need a diagnostic tool you can click here: great tools
P1000 just means drive cycle not complete for emissions testing.
Listen for your fuel pump to run, that might be the issue. If the engine sounds like it is turning over faster than normal, your timing belt is broken.
This is a common problem for a crankshaft sensor failure. When it fails, the engine can not start since the ECM doesn't know the proper position of the crankshaft to give ignition according to TDC (top dead Center). Therefore it doesn't matter how strong your battery is, it won't fire. The fire is only happens when an ignition happens at the highest compression point when a piston is at top and this is reported by the crankshaft sensor. Have this checked out and replaced. Good luck.
Yes, All the years of the ZX2 utilize the same engine. 1998-2003 are all the same except for ECU programing and the MAF wiring. You should not have a problem.
go to gates.com and click the link on the left that says Part Locator & Interchange, put in your car info then look down the page and click the camera next to the serpintine belt. These belts are not usually hard to change, the tensioner pulley should have a 3/8" square drive hole in it to release the tension, I always start at the crankshaft and loop around leaving the tensioner for last, hope this helps, let me know
