Ice Maker is not dispenseing ice. Water Dispenser is working. It appears that the first two receptacles of the tray have ice, the rest are dry. I've selected Ice Plus and took operation out of Enegy Saver Mode. Also turned unit Off and On.
SOURCE: water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position. Only way to tell is to pull the bottom kick panel out and look for the water line disconnect. Separate the line, close the door and try to draw water through the dispenser. If the water comes out of the disconnected line, then the water valve is good.
#2 if water is coming out of disconnected line, then the problem is in the freezer door. There is a heater that keeps the water line from freezing inside the freezer door. It is not repairable!! The freezer door has to be replaced.
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
SOURCE: water wont flow into LG LX259602b ice maker
You may have a bad water valve. The valve has 2 sections, one for the water dispenser and the other for the ice maker. Check those connections in the back of the refrigerator. If everything is ok, replace the water valve.
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
