Vehicle Parts & Accessories Logo
Breakiet Tofaeono Posted on Sep 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Noice from the gear
My harrier 1998 3.0 has a problem of a sound coming from the gear box especially in the morning when the car is just started. I asked an assisstant for help but he said somthing amount the filter. Theres alot of grinding pieces and block the filter. He cleaned it three times but it still has no change. Any technical advice is much appreciated. my email: [email protected]
Robert Plante
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 177 Answers
  • Posted on Sep 15, 2017
Robert Plante
Expert
Level 2:
Cheetah:
Answers
177
Questions
Helped
53921
Points
431
Change the oil and the filter to see if this helps to remedy ghe problem.
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Oct 16, 2008
SOURCE: Hard to start in the morning. Also stalls
This sounds like a fuel pump check valve problem, if the fuel is not kept in the filter and lines by the check valve it drains back into the fuel tank and causes the kind of problems you are having, you can check this by hooking up a fuel pressure guage at the test port on the fuel manifold that supplies fuel to the injectors, run the engine and shut it down, note the fuel pressure at shut down (with the test guage hooked up), walk away for an hour, come back and check the pressure, it should not have dropped more than 5 PSI You can buy a universal fuel injection pressure tester for about $25.00, cheaper than having a shop run the test. If the pressure drops you found the problem, bad news is the check valve is in the pump, the pump is in the gas tank.
Anonymous
  • Posted on Dec 19, 2008
SOURCE: headlights flicker all the time
Hi, my name is ricky and im 24 yrs old and from Bronx, N.Y . I bought my 03 impala in 04 and i had the same problem in 2007 in which that clicking noise happens. The headlights flicker, and even the gauges inside the car would flicker at times. It has nothing to do with fuses or a relay, please dont spend money on that b.s. like i did..lol I will try my best to explain what i did so that you can save some money and time. READ EVERYTHING AND USE ADVICE AT YOUR OWN RISK.
1st of all - I went to a junk yard/auto salvage yard to find a USED part that i needed. Often there are good parts from cars that have been totalled.
2nd- What i asked for was a Body Control Module. This controls most of the electric issues you are having and costed me about 50 dollars compared to a new one that was over $200 and reached up to $500.
3rd- I went head first under the steering column and found where the BCM was located. Poke around to find it cause it is def. there, hidden well. It doesnt take special skill to remove it or find it.
4th-Replace the BCM, but be advised that after you do this, your car might not crank over.My car did crank over because i installed a automatic starter previously so i could have started it with the remote start.
5th- you MUST take the car to a chevy shop so they can Program your car to the body control module this costed me about $250.
All together this information has to help you in someway.
If you have further questions or would like to make a comment, then e-mail me at " [email protected] "
I hope this helps...im not saying it is a 100 percent guarantee for you, but i had this same problem recently and this was the answer to my problem. By the way, never buy a american car again or a GM product for that matter...Kudos
Anonymous
  • 3 Answers
  • Posted on Feb 04, 2009
SOURCE: Mercedes 1998 W210 E240 Auto Gear Selection Problem when cold
Change the ATF, AT filter and pan gasket. http://forums.mercedesclub.org.uk/showthread.php?t=45725
Anonymous
  • 33 Answers
  • Posted on May 23, 2009
SOURCE: mazda 121 manual gear box stuck in gear
What do you mean "rooted" ?
Generally if a manual transmission is stuck in gear it points to one or several of 6 possibilities ( barring any damage to hard parts such as gears or shafts.)
1: Damaged shift linkage.
2: Worn clutch.
3: Faulty clutch slave cylinder.
4: Damaged fork assembly.
5: Damaged synchronizers.
6: Bad throwout bearing.
Be prepared for sticker shock when pricing repairs or parts !
Mazdas are not cheap to buy parts for or to work on.
( thats why I will never own one )
Anonymous
  • 1486 Answers
  • Posted on Jul 13, 2009
SOURCE: 2002 4runner ABS light on and grinding sound
Brake pads worn.Change a.s.a.p
My toyota harrier 1999 doesnt gear up, sometimes i have to restart it so ican drive normally like 5minutes,,when i fully push the gas pedal it makes a ramming sound and it stutters
you are not in USA, so post country.
the harrier here is Lexus RX.
so not posting that , nor posting what engine is in car makes
all answers wrong.
generic answers.
1: get a tune up, (the operators guide has a list. the 60,000 mile (100km) column are the critical parts. as is any cam belt.
1helpful
Volvo transmission
sounds like the transaxle is in need of service. you can go to youre local tranyshop and have them perform a tranny flush
Toyota tazz 1998
check the transmission oil, for metal bits stuck to the drain plug. If you have some then it will be bearing failure in the gear box.
Buick regal gear shift
Speed sensor gone bad .
1999 HZJ75 toyota troopy ...I have what I think is a gear box noice. Noticeably getting worse over several weeks. Gone from a whine to reverberating whine. Occurs worse when acceleration is off but stll in...
I'd check the U-joints first. Then, check for low gear oil level in the gear box.
Also examine it by draining the gear oil to see if it has any metal fragments in it.
If it does, you probably have a bad bearing or something else coming apart.
Knocking and grinding sound coming from front tire area
Check your outer cv joint boot and see if it is severely torn. It sounds like the cv joint is about to come apart, especially if you notice the noice being more pronounce when turning one way or another.
1helpful
On my 1998 dodge grane caravan, I drove 15 miles to a place, parked it for 6 hours. while parked it rained. when I got in the van to start it after sitting for 6 hours, it would not start. lights would...
No not at all. The problem may be with the anti-theft system. Sometimes in older cars, especially Dodges', the theft system starts to act up even though you put the key in the ignition. You may want to have it checked out at the dealership, shouldn't cost that much just to have it looked at.
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
