It only has to pump 7 feet where weve t into existing pipe
Sounds like the pump needs to be de-watered completely and cleaned. There is a pressure chamber that contains, I am guessing here since I hve never taken one apart, a float and a microswitch. If the float gets heavy with gunk or gets a hole in it, it will not float as well and will take more water in the drain pipe to cause it to rise up and activate the micro switch. I don't know how hard it is to disassemble these units but hope it is fairly simple since they are pricey. You said it was only on a sink, not a toilet or both. It is possible that grease has built up (the gunk) and a hot water flush may do the job for you but it will take a lot of hot water flowing through the grinder, that of some grease dissolving drain cleaner.
SOURCE: Saniflo not flushing corectly
Does the shower or sink back up into the toilet bowel after running for a few minuits?
If not:
The bowel is clogged. Fill it with water then use a plunger
SOURCE: saniflo is for my shower only.the pump works then
Sounds like the pump is overheating and is being protected by an internal automatic reset high temperature switch. Have the pump serviced. It might need nee bearings and seals.
SOURCE: I HAVE A PROBLEM WITH A PUMP FOR A SANIFLO
sounds like the pump is jamed with toilet paper or wipes.
You will have to take out the pump to un block it
SOURCE: saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
SOURCE: saniflo pump has a delay, kicks in 15 mins after flushed.
Either the rubber membrane or the microswitch is at fault.
