Question about Kohler Generators Kohler Standby Liquid-Cooled Generator - 30kW, NG/LP, CARB-Compliant,
Kohler generator 30rz62 auxiliary fault
Auxiliary fault
Posted by Chuck Velez on
Wayne Holden
  • 512 Answers
Fourth time. Already solved.
Posted on Oct 08, 2012
Kohler 40EFOZD Auxiliary Lamp starts flashing After 2 minutes.
Make sure you have rated speed and voltage on the out put side.
Oct 13, 2014 | Kohler Electrical Supplies
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
WHAT IS THE MOST LIKELY CAUSE OF AN AUXILIARY FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Check radiator coolant fill right to the top, if it has a low level switch or faulty switch I have seen this
Generator code 0094 01
Can you be more specific? what model Kohler is it, Model number KW etc.
Sep 15, 2013 | Kohler Electrical Supplies
Kohler 20kw RESA "invalid shutdown" fault
I have a Kohler 14Res and an error Invald Shutdown is indication and the engine is not crancking
Jan 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
Kohler 30RZ62 generator Parts
You are going to have to register with Kohler and use this site to get your part:http://www.kohlerpower.com/residential/sectionfront.htm?sectionNumber=13561
Oct 02, 2012 | Kohler Electrical Supplies
Kohler Generators Kohler Standby Liquid-Cooled Generator - 30kW, NG/LP, CARB-Compliant, Logo
520 people viewed this question
Top Kohler Generators Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Kohler Generators Electrical Supply Expert? Answer questions, earn points and help others
