Big black block line straight down the middle of the TV, everything else works but no idea if it is a fault to the TV or just something to be easily done
SOURCE: a black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
SOURCE: a one inch black line down middle of tv
The LG plasma TV with the black vertical bands, may be the bad connections, you can try to reconnect the cables on the X board. If the bad connections on the panel side, you need to replace the panel.
SOURCE: LG 50' Flat Screen TV;
A black line down the middle of the TV can be a few things. You plasma panel might be bad your buffer on that location of the screen might be bad or your logic board might be bad. Teh only way to find out is by replacing the parts , You can get parts at www.interliquidparts.com
