Question about Hotpoint Washing Machines
Could someone email me the fault codes for a hotpoint aquarius wmf740 washing machine please
I need a list of fault codes please
Posted by david brackley on
Michael Vincent Cruz
    Guru:
  • 868 Answers
Hi I see you need the Fault Codes for your Hotpoint Washing Machine
See this link for the info since I do not have your E-mail to send the details I have created this link for your viewing regarding your concern.
Hope this helps.
Posted on Oct 03, 2012
5 Related Answers
edward hayes
  • 12 Answers
SOURCE: Need full list of fault codes for Samsung Washers
try www.samsung.com to download user manual
Posted on Mar 28, 2009
Anonymous
  • 100 Answers
SOURCE: hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Posted on Jan 27, 2009
Anonymous
SOURCE: hotpoint aquarius 1000 washing machine parts diagram
no current
Posted on Apr 15, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
Anonymous
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
H0w do I clean the machine
put it on rinse add cup of bleach
Oct 06, 2014 | Hotpoint Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WF640 - What is Fault code F01 please?
My list for nearly all of the Indesit (Hotpoint, Ariston) washers suggests there is a fault with the motor triac, the bit that controls the motor speed, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Aquarius WD640 Front Load...
I have fault code F06 on my Hotpoint WMf740 machine, what does this mean?
F6 error is apparently a motor fault. The
motor could be jammed, open circuit ,
burnt out. It may just be a broken wire
or connection come off. Check the motor.
Dec 13, 2010 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint aquarius wmf740 that is showing a fault f--5 and wont empty out the water
Something wrong the pump would prevent the machine draining and generate an F5 code.
http://appliancejunk.com/ge/washer/31-9103.pdf
Service manual above.
Jun 25, 2010 | Washing Machines
My aquarius wmf740 has a blockage cannot undo the white water release valve on front bottom right hand side of washer to solve problem. Any help grateful.
tip machine right back and unscrew valve. It is probably caught on something. Hope this helps ( I had a kirby stuck in mine)
Audrey
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing Machines Logo
555 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
