Try to RESTORE to some point that was working before. if work pass the antivirus inmediately. Maybe the toolbar installed is malware! remove it God bless you
Sometimes removing battery will mean the radio has to be re-coded on re-placing the battery.
You may this same situation if your battery went completely flat.
call your nearest dealer and read them out the model number and they would give it to u for free or it could be that its no good aswell can u here music comeing out of it if not check your radio fuse and replace it : )
1. Turn on the computer; then, while the initial screen is displayed, press the Lenovo CareSM button. The Rescue and Recovery screen opens. 2. Enter into BIOS SETUP with F9 on start up or Click Access BIOS. The System Restart Required window is displayed. 3. Click Yes. The computer restarts, and the BIOS Utility screen opens. 4. Check whether the wireless radio is enabled. if it is disabled make it enable.
You either have a bad LCD display OR the connection for the LCD display is loose/off. Its impossible to tell what channel you are on with a 2950 without the screen working, but when you turn the channel knob do you hear any other cb transmitting on ANY channel?? This is a tough one!! I really need some more info on the radio.
Open the case and look at the area that the display is in (front of radio). Slightly wiggle all of the little plugs in that area. If you see the LCD screen come on or flash then you know where your problem lies. If not, then you're probably looking at buying a LCD display for the radio.
Six stations for each band can be stored. 1 Press LIST. Preset screen is displayed. 2 Use MULTI-CONTROL to
store the selected frequency in memory. Turn to change
the preset number. Press and hold to store. You can also store the
frequency in memory by pushing and holding MULTI-CONTROL right. 3 Use MULTI-CONTROL to
select the desired station. Turn to change the station.
Press to select. You can also change the station by
pushing MULTI-CONTROL up or down. To return to the ordinary display,
press BAND/ESC or LIST.
This worked for me (radio in 2003 VW Golf):
Radio says "CHECK" but is otherwise unresponsive. Turning car or radio on/off doesn't help.
On the far right of the radio, there's a round TUNER button. Press it for 5 seconds. Your screen will then show some digits, but the unit is still unresponsive.
Press tuner button again for 5 seconds. Radio should now be 100% again. Let me know if this works for you.
you have the unlock code or the gm code? here is how to enter your code
press the hour set button on your radio until you get the first two numbers of the code, then press the minute set button until you've entered the last two numbers. Immediately press the AM/FM button once the correct code is entered and the code SEC or "secured" will be displayed on the display screen. Now, just turn the radio on, and your ready to roll. There is an additional step you can take to remove all codes from the radio and start from scratch by entering your own personalized 4 digit code so that it won't get you in a pickle again! Just repeat step 4 and you should get a display screen that reads ---. This means the code is out, and you can now program your own code. Of course, once you receive
