Question about Archos 504 500870 Digital Media Player
Battery needed for Archos 504
I've purchased two batteries from MegaCapacity and they are worthless because the batteries are actually installed backwards in the back casing. I've returned them and am still having issues getting credit and reimbursement for shipping. MegaCapacity hasn't been very caring or understanding. I guess that is what you get when you buy something that is made in China these days. Any idea where to get a good deal on a replacement 504 battery?
Posted by ctm0526 on
Pamela Leach
  • Archos Master
  • 1,830 Answers
Batteries and Bulbs.
Posted on Jun 28, 2017
5 Related Answers
Anonymous
SOURCE: Archos 504 RESET button
i press the little gold bump. it worked. thank you so much
Posted on Feb 13, 2008
informatica
Greg Cann
  • 1114 Answers
Hi - You can download the manual from the link underlined in blue below:
Archos 504
Se page 7:
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 21, 2008
nickyj44245
SOURCE: Archos 504 160gb wont start
Take the battery off, and to the left of the battery connetion tabs is a small gold button, push and hold for 10 seconds. It should start up after doing this.
Posted on Dec 03, 2008
Anonymous
SOURCE: My Archos 504 will not power up.
Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in.
Reset button is located under the battery. So remove the battery and loo for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Thanks,
Ed
Posted on Mar 02, 2009
Anonymous
SOURCE: Archos 504 hard drive upgrade
  • go to archos.com
  • go to support and account near top of your screen and go to downloads
  • the archos website should tell you what to do next
Posted on Oct 20, 2009
Product key verification
JWR9T-HFR92-74RQ7-3FRMB-CY676
hope this helps
May 13, 2012 | Microsoft Office Home and Student 2007...
Amcor 3990 GPS navigation device screen backwards
If your screen is actually installed backwards take it back and exchange it for new one, but if the screen is not actually installed backwards then go into the settings screen on the gps unit and find the orientation section, this will change the display to something a little more readable to you. And as a side note some of these things look like they should be straight up and down but they actually designed to work sideways, gives you a wider view and the manufacturer a little more screen room to put more information onto the screen.
Jan 02, 2010 | Navigator Amcor Amigo 4300B GPS Receiver
My Ipod 5th gen. Is not powering anymore. I was replacing the battery. On accident I tore the hold/Headphone jack lead. I know I need to buy a new jack... But Now when the I plug the Ipod in the apple...
The xx iPod face means the iPod cant find any information on the hard drive. I think the battery you purchased is worthless as it appears other delicate components have been damaged. Get a new one?
Nov 25, 2009 | Computers & Internet
After removing the CMOS battery and letting the board sit overnight, as instructed by Intel. I replaced the battery , and now. no beeps, or CPU fan. the status light on the board still lights sayin that...
Check to be certain that you didn't install the battery backwards. (This will cause this exact problem). I have seen a case where the BIOS chip was faulty and actually lost its internal charge, resulting in no BIOS. This is rare. I still think the battery is backwards.
May 30, 2009 | Intel D865GVHZ Motherboard
Battery goes dead after 3 hour use
As the battery charges and charges the charge time declines. You can get a high capacity battery for your garmin for about twenty dollars here:
http://www.megacapacity.com/23903.html
May 07, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 765 lithium battery will not hold a charge more than 15 minutes!
This is kind of a late response, but this post may help other people. I had the same issue and was ready to have Garmin exchange my battery until I called them today and spoke to Tech support. They helped me upgrade the firmware on the unit (didnt take long) and so far the problem has been resolved. I have had it on for two hours without fully charging it, which is better than before when it only stayed on for about 20 minutes. I recommend that people with this issue call them first since it appears to be a common issue with this model nuvi.
Mar 27, 2009 | Garmin BATTERY PACK, LITHIUM-ION, DC 20
Non starting Jota
32 amp brand new its been on charge for about 18 hours Acid for battery was put in by a dealer all electric functions working except the starter when the starter button is pushed there is a click and I can feel movment in a solonoid in front and just above the battery (in an ally case) all nuts to starter motor removed cleaned and re tightened Fuses checked (I can only find 2) these fuses are located behind the left side of the battery in a little black cover are perhaps there more fuses which are relavent to the starter the bike is in my workshop and I cant really get a go at jumping it on my own. I did try jumping when I thought it was the battery but it wouldnt go. I thought it was due to NO charge in the battery. Try a single jump lead from the +'ve on the battery direct to the starter motor. A screwdriver across to 2 solonoid connections does the same thing but is harder to control. You need to be careful as if there is an internal short in the starter motor you can run the risk of serious burns from very large fault currents flowing. Next is the poxy short battery negative to crank case...replace with a longer one to the actual starter motor 8m/m mounting bolt ( closest 8m/m to the barrel is more neat ). Less hazerdous is to get a cheap mumtimeter and measure the voltage across the starter motor when you press the starter button some times it is just a dirty segment on the starter motor remove plugs from cylinders, load the HT leads with removed plugs, rest against engine and engage top gear. Press the starter and rotate back wheel slightly backwards ( rocking motion ) going backwards engages the jaming roller clutch to move the starter off the dirty segment if present,,,
Nov 10, 2008 | 1979 Laverda 1000 Jota
I have just purchased SimCity4 but cannot put in that 20 digit registeration code as it isn't on the CD case, on the back of the install guide nor inside it. HOW CAN I GET THE REGISTRATION CODE? I've the...
I returned it to the store for a refund. Not having the registration number in or on the package and the inability to get contact with customer support for the game made it worthless.
thank you for responding
Jul 05, 2008 | Lands Phones
Not charging
it's not replaceable you have to send it in.
Jan 30, 2008 | Tomtom GO 910 GPS Receiver
How do i replace the battery on a garmin streetpoilot c330?
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Sep 10, 2006 | Garmin StreetPilot C330 GPS Receiver
Archos 504 500870 Digital Media Player Logo
371 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
