240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
SOURCE: Fisher Paykel Washer IWL 12 error codes 130 & 240
Had the same problem cleaned the terminals worked for a bit and came back. The problem is that the little circit board that the plug goes onto that sits between the winding of the motor the copper tracks are so small and they corrode. If you are handly with a solding iron you can replace the tracks with small wire, its mainly on one leg of each of the transistors that are all parrelled up. You can tell because it goes black. Or the easy way just take off the motor unpluging the sense plug then the three main power connectors Yellow, blue and red making sure you mark the correct order to put them back on. The sensor board just pulls out of the windings with a little arrow to but it back in the right place and buy the small board it has the part number on it to find it on the web. I only has three bits on it can't be expensive. Soldered mine up works a treat make sur you clean up the plug aswell, it mainly played up in humid weather.
SOURCE: how do I take apart my fisher & paykel top
Hi just read your posting.Now if you look under the machine to the front right you will see a fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely.Put the machine back on its feet and select a spin cycle and push the start button.The machine should start to drain.Please reply on how you got on or if the machine still does not drain or for further assistance.Looking forward to your reply.
SOURCE: Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
