The microwave went totally dead.
SOURCE: Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
SOURCE: My LG microwave went completely dead. I is only 3
under the outer cover,its either a 10-15-or 20 amp ceramic safety fuse avail at most hardware stores, the amp rating is on the side of the fuse, if the new one blows then either the H.V. diode/capacitor or the magnetron can be suspects
SOURCE: LG lmvm2075st microwave control panel problems.
"On each panel the board surrounding the same diode is burned"?
Maybe that's a three-tap power relay, not a diode?
I'd be very interested in this and I have the service manual here which you can download.
Feel free to contact me directly (and
please include your full model number from the tag in or on the
unit) for a free estimate and free tips & do-it-yourself advice.
Also, if you can send me a photo of the burned area, that would be helpful.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Our LG LMVM2075ST microwave touch panel does not
Sorry to read about your problem, I hope this helps you out.
you will have to contact a service company, microwaves are complex. if you order a part and try to fix, their are no returns. plus lg parts take a long time to get, and then way the cost of repair.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to
open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
