Question about Apple Powerbook G4 17" 1.67 GHz SuperDrive Mac Notebook
Want to free up space on my internal hard drive (Apple PowerBook G4) without
Posted by speranr on
  •  Robert Allocca
    Robert Allocca Oct 03, 2012
    It appears you didn't finish your question.
  • speranr
    speranr Oct 03, 2012
    Thanks. I don't know where the rest of my question went! I would like to know how to identify and remove data from my hard drive that doesn't need to be there.
Hancel Diaz
    New Friend:
  • 44 Answers
Mac do not waste space, I recommend you to use an external hard drive. Try to find one with twice capacity that your computer's hard drive.I mean, if your computer hard drive is 500Gb, then find an external drive with 1Tb
Posted on Oct 03, 2012
5 Related Answers
Sindre Rikheim
  • 13 Answers
SOURCE: powerbook g4 going to white screen only!!
Do you have any external harddrive attached to it? If so, remove it before restarting. Try to start it up in safe mode by holding the Shift button down at startup: http://support.apple.com/kb/HT1455
Posted on Apr 16, 2009
Anonymous
  • 40 Answers
SOURCE: apple laptop won't turn on
Try to boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot.
If so run disk utility from the cd and repair the disk as well as permissions.
If this is successful your computer "should" be repaired. If it still has problems booting, Use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Posted on Mar 01, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: how to replace the lcd on a powerbook g4 model m8407
Here is a service guide for the Powerbook G4. It has the step by step instructions.
http://www.powerbookmedic.com/xcart1/files/G4alum12.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 11, 2008
Anonymous
  • 178 Answers
SOURCE: Problems with Apple 15" PowerBook G4 Aluminum 1.25GHz LCD Display Mac Notebook?
The coonection on the(LCD AND LAPTOP IS BAD The wirng )You have to have it taken apart and fixed. I can do it if you live in California or ship it to me. But that is what the problem is.
Posted on Feb 12, 2008
thehumble1
Daniel Herd
  • 137 Answers
SOURCE: PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
Posted on Apr 17, 2009
Sims 3 wont install onto my powerbook G4
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
Oct 15, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I dont know how to reboot my powerbook g4 without using the cd?
go into system preferences and goto startup disk and click on Mac OS X 10.X.X
Jan 17, 2011 | Apple PowerBook G4 Mac Notebook
Apple PowerBook G4 not coming out of sleep mode
the issue is bassically with Hard drive data cable.Still check the system by reinstalling the OS.or else replace the hdd data cable.the issue may get solve
Apr 13, 2010 | Apple PowerBook G4 Mac Notebook
Can't connect to a second internal hard drive via network on MAC
Mac OS X will not file-share any non-HFS volume over a network. However, you can set up such sharing manually if you are willing to use the command-line interface by following the detailed instructions at
http://www.macosxhints.com/article.php?story=20090216180227216
Mar 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook G4 is not working When I put a CD in 2C the computer spits it back out without reading
You need to replace the optical drive. Go to web site of Other World Computing and order a CD/DVD super drive which will burn/play discs and even burn on dual layer discs. Cost about $80 US plus your free labor to install the thing.
Mar 08, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple dard drive
Hi, I'll need more info to help you...
What is the MacOS X version ?
Model of PowerBook, speed, Ram HD Size, DVD?
When was the last time it worked properly ?
What would you say happened to make it lock up like that ?
Did you change anything ?
Are you talking about the internal drive or an external drive... ?
Please advise...
Mar 18, 2009 | Apple PowerBook G4 Mac Notebook
DVD player skips audio and/or frames
PowerBook G4 is at least a five-year-old machine at this point. A DVD drive can **** in lots of dust in five years. Try hooking up to an external DVD drive. If it plays the same discs with no problem, you need a cleaning or replacement. Frankly, an external DVD drive is cheaper than replacing your internal drive.
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
What is eating my hard drive?
Hi!
Please download this disk cleanup tool for apple. It is called OnyX. Download and install it and it will free up your space which is stuck up somewhere between.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Apple PowerBook G4 Mac Notebook
Apple Powerbook G4 17" 1.67 GHz SuperDrive Mac Notebook Logo
87 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
