please first refer to table of contents in your dishwasher's manual to determine how the 3-hour delay is set. You might have accidentally left you step. Using the procedure directly will help you avoid that. Thank you.
turn dial to off. hold down both delayed start and spin select buttons and turn dial to the left one click, to the cold position. keep holding button until you here a click. let go of buttons and turn dial to off. Every thing should go back to normal. Just fixed mine and all is good.
its the drain pump see if you can take it out there small and easy to get to,also you see a black ribbed hose that goes to the drum to the pump see if there any thing in it.The drum is inclosed.try running 2xclorox through machine.
It is your control board that has failed. It is time for a new machine. It is a common problem. If it's under warranty get it fixed but the machine is starting to wear out. Unplug and wait for a clicking sound this will be the electronic door lock releasing.
There are hidden cheats (just like a video game)
this is cool try it out.
1. ignition off
2.Press and hold trip meter button(left black button) down and turn igniton kry to first position. Keep the button pressed about 5 seconds until the words Oil Service or Inspection reset appears on LCD display.
3. Release the button then press and hold till reset begins to flash
while the display is flashing let go then press again.
the display will read END SIA and your all done.
In practice you have to make the inputs quickly, do not delay as you will have to start over
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Here as in some other posts, you can try to RESET the firmware in the menus. Go through the menus and find where it says something like reset all. What this does is to reset it back to factory settings. Then set the options you like, and then try the camera again.
Check the diff. modes for the picture taking. See if the flash can be turned off.
