Amp cuts out when volume is increased. Seems to be getting worse can only get the dial to about 10 oclock before it starts cutting in and out.
SOURCE: Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
SOURCE: clipping amp
hi first disconnect all spks, then turn on the amp. if amp power lite stays on bright then proceed to connect one speaker or sub to the amp. if the amp lite dims during any spk connections then it may be that the spk is faulty or there is a DC voltage (dc offset) emitting thru that particular channel. also check all spk impedance before reconnecting them to the amp. cheers.
SOURCE: interior speakers cut out when the volume is turned up
You may have speakers of an incorrect impedance attached to the unit since the problem occurs when audio signal level is increased and the current goes up.The unit is shutting down to prevent damage. I would check the speaker connections and make sure that the speakers impedance are matched for the unit you are using.
SOURCE: i bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
SOURCE: Why does my KAC-8404 cut off at high volume bass?
My uncl had the same problem and he went back to the audio shop twice...Then called me...I discovered that the powr cords they used were not thick enough,giving the amp a low current to work on...but if you have the original cords you got when you bought the amp...it might also be a weak power supply....try playing the music while driving on a high speed or while reving the car to give more voltage from the alternator...If that doesnt work...come and shoot me please...im out,PEACE
Ok thanks. I think I will give a bit more info. I have a Audiolab 8000A amp and a pair of Wharfedale (not B&W )519 C Class speakers.I have just been reading the Audiolab manual and it describes my problem as muting when an overload or short occurs and will continue to cycle muting every 4 seconds until problem is fixed.Turning down the volume allows me to use the amp however not to increase the volume too much. Other than take it to a Technician is there something I can do?
