Question about Toshiba Televison & Video
How to remove little rainbow on my tv - Toshiba Televison & Video
Posted by jflanagan69 on
Tom Russo
    New Friend:
  • 30 Answers
If it is a crt television you can try degaussing it--you will need a degausing coil
Posted on Oct 01, 2012
Strange rainbow.reenish type effect
Did you notice any better picture when you play a movie on a DVD player or using a flashdrive on this TV? Is the picture quality better? Or is it the same? Try to check another cable connection or try to play TV channel thru internet. The last option in this case is to show a TV mechanic for he would better understand which part to order.
Jan 20, 2014 | LG 60PZ550 3D Plasma TV
My e series rainbow has stopped picking up and the dust gathers on the top of the nozzle. It will pick up a little when I push it forward, but when I pull it back dirt and debris comes out of the noz
<p>Did you recently remove the brush roll? If you installed the brush roll in backwards, then this can happen. You can <a href="http://www.rainvac.com/rainbow-vacuum-manuals">download the manual </a>on how to replace your belt and install brush roll correctly.<a href="http://www.rainvac.com/rainbow-vacuum-schematics"></a></p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Feb 23, 2013 | Rainbow E series Canister Wet/Dry Vacuum
How do i get rid of a little rainbow on my tv
has a magnet been close to your screen cuz this will do that.
Sep 30, 2012 | Toshiba Televison & Video
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
I have a 3 year old mitsubishi wd-52526 lcd projector tv that is starting to have some focus/image alignment issues - in general picture is a little out of focus and there are rainbows around things at the...
the differnt guns are out of alignment. Your tv has 3 lcd screens, a red, green and blue one what overlay to form the image. Sometimes they move slightly for what ever reason and that causes the rainbow and out of focus picture. Its something that a trained pro should do but is a cheap fix and won't set you back too much
Oct 20, 2008 | Mitsubishi Televison & Video
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Cleaning the flter on a e series rainbow vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=749568
Cleaning the filter on a e series rainbow vacuum
Posted by jonesjpc on Jul 06, 2008
This one does not have the tabs to depress as but has two screws in that area still doesn’t see how to get to the filter. Also I need instructions to replace power cord; On the E series single speed.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Rainbow E Series there really is no actual filter – the water is the filter for this particular vacuum. Before you remove the separator under the motor, place a newspaper or towel under the Rainbow without the water pan under the vacuum and then turn it on for a short period of time and spin the water moisture out of the motor and separator; then some of the maintenance is to remove the separator under the motor and clean that and then replace it. As far as replacing the cord there are screws under the Rainbow that need removal and then you can get to the end of the cord for replacement. The easiest way is to mark your wires and the cord will be much easier to replace otherwise check the owner’s manual for cord replacement or check with your local vacuum cleaner dealer in your area or to cal the cust serv @ the Rainbow factory for questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Sony KP-57WS510 rainbows and arches
no the shape doesnt matter as long as the STK numbers are the same. I would make sure that the replacements are origional sanyo ICs as often the cheaper versions do not last very long.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
My Rainbow E series power switch doesn't work
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Jun 25, 2006 | Rainbow E series Canister Wet/Dry Vacuum
Televison & Video Logo
14 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
