I was watching TV and the picture just blinked out and the TV turned off. When I turned it back on I only got sound. And now the TV won't turn on at all.
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
SOURCE: DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
SOURCE: TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
SOURCE: My lamp on my Mitsubishi WD65733 DLP TV actually
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
