SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
SOURCE: How activate hourly chime in Citizen Aqualand
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Citizen watch manuals. Rate me, plz.
SOURCE: the time and chimes are out of sync for our tempus
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
SOURCE: How do you set the
Please be guided by this rule:
1. Use the minute hand only
2. Never move the hour hand by itself to set the clock
3.Never move the hand while the clock is chiming or striking.
These are the instructions. Please be guided too that It will take up to twelve hours before the chime sounds completely synchronize with the correct time.
1. Open the clock door to gain access to the clock hands.
2. Set the day/night lever all the way up --the strike position-- if applicable. Also, if your clock has automatic chime sequencing, turn it off. Setting the time with the lever set on "auto" may damage the chime mechanism.
3. Move
the minute hand backward to the correct time. Do not move the hour
hand--it will move as you adjust the minute hand. Moving the hand
backward removes the need to wait for the chimes to sound when you pass
each quarter hour. The chimes automatically synchronize with the time.
It can take up to 12 hours for the chimes to sound properly and in sync
with the time
I hope these will help you in your setup while patiently waits until the chime sync with your time.
Thank you for using Fixya.
Alp
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
