Question about Generac 6500 Watt Gasoline Generator - 49 State Compliant
What's the mag or coiul on a generac 6500 generator 13 hp
What is the mag or coil on it
Posted by debbiejl68 on
Wayne Holden
  • 512 Answers
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
Posted on Oct 08, 2012
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
I have a Generac 6500E. The electric start turns over the engine but will not start. Pull start works fine
If the pull start works, but the electric start doesn't try the following. Either give the battery on the generator a full charge, and if after a full charge it doesn't start, get a new battery.
Jan 20, 2013 | Generac GP6500E - 6500 Watt Electric Start...
Coils on transfer switch got fried when utility came back what could have caused this
possible failure of a relay. contact generac,sometimes they will accomodate you with new parts
Oct 08, 2012 | Generac Guardian 200 Amp Transfer Switch...
What's mag
A mag or magneto is a coil of wire that is "excited" by a permanent magnet thereby inducing a high voltage to fire the spark plug with. Most single cylinder lawnmowers use mag and point systems to fire the plug. Coil is hard mounted and the permanent magnet is part of the flywheel with the points mounted under the flywheel.
A coil is a two coils of wire, one is connected to ground on one end and the other end is connected to either a set of points or an electronic switch, either of which turns on and off the current through that coil. When the coil discharges its electrical potential, its magnetic field collapses, inducing a high voltage in the other coil which is used to fire the spark plug.
Sep 30, 2012 | Generac Rv Generator - 6,500 Watt - 6.5 Kw...
Can i use my welder with my generac 5000 generator? my welder is 220VAC.
probably but it may be a streck 1300 watts may do it but it depends on the draw of the welder and it will be maxed out thats 13 100 watt light bulbs running at the same time use common sence
Nov 29, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
Generac 6500 mega force generator lost compression
remove cylider head check the gasket the inlet and exhast valves also inspect the piston if you see no sign of damage remove the piston and check the piston rings
Mar 16, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
Governor problem on 9 hp vanguard engine
Go online to Generac and they have parts list and owners manuals online. They will ship you parts.
Jun 25, 2009 | Generac 5724 GP Series GP3250 Portable Gas...
Generac 6500 Watt Gasoline Generator - 49 State Compliant Logo
155 people viewed this question
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
