Question about Vivitar 283 Flash
Vivitar 283 won't fire
Hi. I have an old'ish 283 and it seems to charge fine but it won't fire from my cameras hotshoe. It DOES fire manually by pushing the button on the back of the flash, however when I tried on several different hotshoes (different cameras) it wouldn't respond. Is it possible to fix this? Thanks, Serge
Posted by serge82 on
TimHu
    New Friend:
  • 23 Answers
Since the flash is working on test, it means the connection to the camera via the hotshoe is not working. With the flash on and ready light showing that the flash has charged, take a small thin copper wire and short between the the metal spring on the side of the hotshoe (in the slot) and the round metal contact tip of the hot shoe. This should cause the flash to fire if the internal connections to the shoe are working.
If the shoe is working then it must be the camera that is not working. Many modern digital cameras cannot fire older flashes directly, because the voltages on these older flashes are too high. This could damage the camera or if the camera has protection against the high voltage, that will make it impossible to fire the flash. In that case you need an adapter. These are available cheaply. You should try borrowing a modern flash to test that your camera is still working and has not been damaged, if it is a modern electronic camera.
Posted on Dec 27, 2017
5 Related Answers
Anonymous
SOURCE: Vivitar 283 charges but fails to flash
I had the same problem with my early Vivitar 283 flash.  I discovered that the thyristor on the trigger board tested as an open circuit.
Trying to find a replacement for a 30 year old thyristor semi-conductor proved to be fruitless.
My solution was to purchase a broken, late model Japanese 283 flash off of ebay and transfer the trigger board to my early Japanese model. The late model thyristors could handle more heat.
Problem solved.
Posted on Oct 27, 2007
carusoswi
  • 4 Answers
SOURCE: wireless flash trigger for vivitar 283
I purchased the Wein Slave Foot. The metal foot is designed to repair the plastic foot that, apparently, is prone to breakage. Mine is not broken, but I purchased the Slave Foot because the blurb stated that it would make my unit serve as a remote slave.
The setup works fine with my Sony A700 using either the built-in flash or in combination with my proprietary external Sony flash.
I have just purchased another used 283 and will be ordering the Wein Slave Foot from B&H in the morning.
Caruso
Posted on Jan 03, 2009
Anonymous
SOURCE: vivitar 283 won't flash, exept through pc terminal
Hi if it is a Japanese 283, CAREFUL, you are working with ~300V
remove the sensor from the front. Short out the terminals at 7 o'clock and 11 o'clock with eg a paper clip, and then charge up the flash . Short the centre terminal with the one at 7 o'clock. If the flash fires, then it probably needs a replacement hot shoe from ebay. If it doesn't, it is a simple job to fix for an electronics worker. Manuals are available on ebay.
I repeat, careful with the Japanese flashes, you will have ~300 volts near you fingers, so if you are less than 100% confident that you won't blow the top of a finger (or worse), get an electronics worker to look at it.
Don't use the ebay hot shoes on a 300 volt flash, you will have the 300 volts out in the open and ready to bite you - have a look how well hidden the second contact is on the Vivitar plastic hot shoe.
Good luck the Feral Photographer
Posted on Jan 05, 2009
Anonymous
  • 105 Answers
SOURCE: my vivitar 283 flash won't turn on. I checked the
Check the contacts for the battery to make sure they are clean and shiny. Then insert 4 brand new AA batteries observing the correct polarity and try again. Also check your users manual to be sure all of your setting and connection to your camera is correct.
I hope this was a help to you and good luck!
Posted on Nov 13, 2009
Anonymous
  • 8 Answers
SOURCE: the hotshoe foot on my Vivitar DF-383 flash unit
Don't buy anything before you shop the bay and craiglook.com (don't put in a zip code) for another flash. Often a used flash is reasonably close to the price of a new part. Your flash may be worth the repair, I am not looking at it so I can't say.
If you want to get a part, and if the flash is a few years old, there will be broken models for sale everywhere. And Photo.net has a forum for everything related to cameras. I often get parts sent to me free even though I am willing to pay for them. Someone will have the part you need.
Other than that you can call the maker and ask if they will send you a part free. I am amazed by how many companies are willing to send free parts on things that should not have broken. It never hurts to ask.
Best wishes.
Posted on Oct 09, 2010
What coloured wires go to which contacts inside the hotshoe of a nissin di622 for nikon ?
Since the Vivitar 283 is a non-dedicated strobe, I believe the crux of your question is which wire goes to the central contact - the only one that will fire the flash. I can't tell you the color but perhaps this will be enough to get you started. Might I suggest that if you are inside the camera but not able to see the pentaprism shoe contacts, you might employ a low voltage tester or ohms meter connected to the central contact and various wires you can see on the ribbon cable or circuit board. An ohm meter between the shoe rails and the central contact should show slight needle deflection when the shutter actuates at a speed within the x-sync range. Digital meters likely cannot show the very fast make and break connection as well as analog meters.
May 25, 2014 | Vivitar 283 Flash
Vivitar 283 not firing on Nikon FM
Did you get the cord with the flash unit, If so then try that to see if it's the camera, Cords are cheap to buy if you didn't rec it,
Sep 21, 2017 | Vivitar 283 Flash
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Nov 16, 2009 | Vivitar 283 Flash
Vivitar 2000 with canon xs
Trigger voltage doesn't have anything to do with the power source. Even though you're only giving it 6V (4 1.5V batteries), it ramps it up internally for the photo tube.
Old cameras used a mechanical switch to fire the flash, so the voltage didn't matter.
New cameras, like your XT, have an electronic switch and eventually will burn out, like Anonymous said. They want 6V at the hotshoe. You're giving it 56V... I know it works now, but it'll fry it eventually. You can get a hotshoe adapter that will isolate the voltage from the camera.
Dec 25, 2008 | Vivitar 2000 Flash
Vivitar 283 won't flash, exept through pc terminal
Dec 14, 2008 | Vivitar 283 Flash
Vivitar 283
if you have PC connector for the camera or a hotshoe.
May 10, 2008 | Vivitar 283 Flash
Nikon SB600 flash menu locked.
Nikon hot shoe is rated up to 250V (canon's is rated up to 6V) so you can use almost any tipe of flash, except maybe for old studio flashes.
Vivitar 283 (older versions) is ~200V rated, and much lower on newer versions. It should work.
Apr 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Vivitar 283 flash will not work on camera.
To test everything except the camera, just short the contacts on the Wein protector. If the flash fires, the problem is in your camera, and maybe the protector did not do its job as good as expected.
Good luck
Aug 29, 2007 | Cameras
Problem solved.
Mar 15, 2007 | Vivitar 283 Flash
Vivitar 283 Flash Logo
223 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Barbat Nae
Barbat Nae
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
