I have a BT hub 2 for wireless connection to two HP Pavillion laptops. My wife has decided to work from home and needs an office with a fast connection. The room she is using is the furthest point from the hub with a load bearing wall between her and the hub. The signal strength on her laptop is barely 1 bar. I cannot move the hub any closer and do not want cables running upstairs from the hub. These were suggested as the easy method for a guaranteed connection. If only!
SOURCE: Connecting my Home Hub to Netgear to have wireless setup
set ip in your router is 192.168.0.1 then give this ip as gateway in nyour computer or laptop in which u use internet. this is useful when u have LAN.but if u havent lan then enable dhcp in router and set ip automatic option in your lan card tcp-ip p\ropteties.
that sit
SOURCE: lost internet connection to my 2nd wireless p.c
Suggestion: Move your router. Your PC 3 appears to be in a 'dead zone' so to speak.
SOURCE: bad signal at home
Free and easiest way to fix a signal problem in a house:
http://www.freeantennas.com/
Should boost your signal by a couple decibels
SOURCE: How do I set up a router to extend the range of a wireless hub?
You would normally set it up as an access point. But bridge would work too.
SOURCE: I have a BT 2-wire hub with networked printer.
First thing, Does your printer have a wireless facility built in? If not it has to be connected to the hub with ethernet.
Normally setting up a wireless printer involves using cables until the set-up is complete. It's nothing to do with the router but all to do with the printer.
Best thing is to go through the manual.
