On our 03 holds silhouette there is something that looks like a pump maybe. It has lots of rubber hoses around. What is it?
SOURCE: Lots of mold around rubber
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
