2005 Chevrolet Impala Logo
Tim S Posted on Sep 30, 2012
Car only blows heat on passenger side, Drivers side still cold even after replacing the actuator. What else could it be?
The car doesn't blow any hot air on the driver's side of the car. I replaced the actuator on the driver's side and did the reset with the fuse. It still only blows cold air.
2answers
Air conditioning system, when you turn on the air conditioner the drivers side blows cold air and the passengers side blows hot air? What causes this problem?
The most common cause of this is that you have a stuck air temperature control blend door, this can be a motor actuator issue or a jammed door or both (common). To replace both parts you will need to completely remove the dash from the car to access the blend door.
On driver's side, why does it blow cold air?
drivers side temp door actuator in heater case is likely stuck .what kind of car!!
7helpful
3answers
Driver side blowing hot air passenger side blowing cold air
I'm having the same problem except on mine it's the driver's side that's blowing cold. Do you have the pictures in a finer resolution? I can't make them out and when I zoom, they are too grainy. Does the replacement require removing the dashboard? What's the general cost of the acuators? Are they readily available at like NAPA or other parts stores?
1helpful
Dual front climate control - the passenger side is blowing cold, the driver's side isn't. Changing temperatures on control didn't help. Today's high was an unbearable 109, but since the...
the blend door actuator for the passenger side is not moving. need to check the actuator and also the signal from the climate control to the actuator.
Driver side heat blows cool air passenger side blows hot air. Both thermostats are on hot, recently had no heat flushed radiator and got half heat
Hello, this is cused by the drivers side temp door actuator. there are two electric motors that move the temp doors from cold to hot. there is one on the drivers side and one on the passenger side. you will need to replace the one for the drivers side.
  • Remove the left instrument panel (I/P) insulator.
  • Remove the knee bolster bracket bracket. Disconnect the electrical connector from the left air temperature actuator.
  • Remove the mounting screws from the left air temperature actuator.
  • Remove the left air temperature actuator.
  • 3helpful
    I have a 2004 monte carlo and my driver side heat does not work it blows out cold air even when the control switch is on the heat my passenger side works fine
    Hello and welcome. this is caused by a bad temp door actuator for the drivers temp door. you will need to replace the drivers temp door actuator. this is a electric motor that moves the temp door from cold to hot and hot to cold
    1helpful
    I have a 1995 oldsmobile. The passenger side blows hot, regardles
    try disconnecting the battery to re sync the two temperature control blend doors, if that doesn't work u will need to replace the control head or the drivers side blend door actuator.
    61helpful
    3answers
    AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
    Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
    My 2004 Chevy Tahoe LT (40,000 miles)aircon blows geart cold air out of the drivers side and rear blows geart cold air, but the passenger side only blow hot air. I have cycled the air on and off, tried it...
    Temp. actuator stuck on heat , probably . Manual or automatic climate control . Electrically controlled temp actuator , or the door is stuck in heat side.
    Top Chevrolet Experts
    ZJ Limited
    ZJ Limited
    john h
    Thomas Perkins
    Thomas Perkins
    Are you a Chevrolet Expert? Answer questions, earn points and help others
