SOURCE: 2007 honda odyssey warning light
That isn't the light for low tire pressure. Low tire pressure will have what looks like a tire- flat. It is your VSA someone probably hit the button and accidentally. look to the left of your steering wheel there is a button that says VSA push it and see if it turns it off. I notice that this post is pretty old, so you may already have gotten the answer from your dealer, but I'm posting in case someone has the same problem later on.
SOURCE: dash lights not working
check the headlight relays use a continuity tester aswell, something is touching and shorting the system out, check the fuses and relays under the dash for the headlights, it may be there. somethings getting to much power and shorting out or bad earth
