Question about Lewmar Concept 1 Windlass 5/16" Gypsy With Switch Kit
Windlass goes down wont go back up
Able to put out motor works but motor turns off when trying to get anchor up
Posted by Farrell on
Steering on starcraft fishing boat
Some one has assembled the rack to the wrong side of the steering wheel shaft, OR put the cable down the wrong side of the boat, OR switched from a pivot steering anchor to a transom mount anchor (you would have had a drag link left over.)
Jul 11, 2012 | Light Boating
HOW TO OPEN HARRIS GARAGE DOOR WHEN SPRING SNAPS
In such a situation replace the spring assembly and shaft that it is attached to. Then determine how many winds you need to add to the windlass for spring tension to get the door to lift. Depending how the door track it is set up the outer wheels that take up the lift cable spool about 16 to 18 inches of cable per revolution. The spring gets tensioned by sticking a length of half inch/13 mm rod into 1 of the 4 tensioning holes of the windlass that are cast into the clamping end of the spring and turning tension onto the spring by way of that windlass to lift the door once the cables are attached to the door and then clamped into the wheels, once the approximately correct lift height has been cranked into the spring.One rod would need to be left in place to hold windlass firm until the set screw is tightened. Then you can put on a hard hat, unlock the door and lift slightly- the rod will fall out if you wound the spring the correct direction.and the door should rise again with ease.
Dec 31, 2011 | Home Security
Hello, I have a lewmar Concept 1 windlass that worked fine for May/June, then on vacation in July it started cutting out. If I let it sit for a minute, it would start up again, only to quit again after...
Check the brushes and if they are short just replace them.
This will solve the problem.
There is thermal cut out which will protect the winding if its hot and will stop windlass and after cooling down it can run again.
Oct 28, 2017 | Lewmar Concept 1 Windlass 5/16" Gypsy With...
Got a 84 k-5 blazer the back window rools down but wont go back up and the motor works but the cable that goes into the motor wont turn
I had a similar problem, but I could use a cordless drill to turn the cable. If the cable won't turn, you might try a new cable, since it might be broken in the middle. I had a bad wire in the tailgate, had to splice a new one, couldn't get at the wiring behind the glass. Have you checked the switch on the dash? I am having a problem with that, too. 26 years old, it doesn't spring back so well.
Nov 12, 2010 | 1984 Chevrolet Blazer
Sprint 600 Vertical Windlass blows fuse
Is this the main fuse???
600watts motor on a 12V system drops 50amps...
You should have an 80 or even 100 amps fuse for the power cables!
Jun 15, 2017 | Boating
Powerwinch windlass not working.
Of course, first check the voltage at the connections to the windlass. Have someone operate the switch while you measure with a volt meter. If no voltage check breakers, or fuses. Heavy current devices like a windlass will often require fuses near where they connect to battery power.
A windlass requires a LOT of current to run. Not just voltage. Trace the wires from the battery connection all the way to the windlass. If possible, loosen any connections (ex; a lug with a nut or bolt) and clean with a wire brush then reconnect. Be sure to disconnect the battery while cleaning. Many times wires will corrode past the insulation. Especially if they were not tinned wire to begin with (tinned wire has a silver shine, regular copper has a copper color and typically turns dark or even black when corroded).
Since a windlass requires a lot of current, often there may be a relay near the windlass that might go bad. Listen to see if this is activating while someone operates the switch.
Apr 27, 2017 | Powerwinch 36' Class Freefall P77736 775...
I have a Lewmar Sprint 600 Windlass. It was working, however, my battires were low and there wasn't enough power to run the windlass. I think trying multiple times, I trick the breaker. I charged the...
I had the same problem this past weekend. Took the complete unit apart and found salt and all kind of moisture in the motor itself. It sure was not sealed very well from the factory. I am unable to find the motor sold separately, therefore I am taking my unit to an electric motor shop. I am guessing it will cost me about $100-$125 to get the motor reworked. It was extremely easy to take apart.
With the moisture in the motor, there was simply too much resistance for the windlass to turn, If you get your tension wrench and work the windlass back and forth, then hit the button. It should work temporarily.
Good Luck,
Tony
Apr 14, 2009 | Boating
Creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Jul 20, 2008 | Dryers
Shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Lewmar Concept 1 Windlass 5/16" Gypsy With Switch Kit Logo
87 people viewed this question
Top Lewmar Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Lewmar Boating Expert? Answer questions, earn points and help others
